255/40/17 or 245/45/17 for my E90 possible? - Bimmerfest - BMW Forums
Old 02-22-2014, 10:18 AM
Shouter Shouter is offline
Mein Auto: E90 330i
Hi guys,
I see that a lot of of stock E90s come with broader tires on the rear up to 255 or even more. however, front tires are always 225!! is there any restrictions for broader tires on front?
My 330i stock tire size is 225/45/17, and 8JJ rim both front and rear. I have a couple of combinations in mind:
1- 245/45/17
2- 255/40/17
what do you think guys? is there restrictions or information from people who tried the same?
Old 02-23-2014, 12:26 PM
Mein Auto: E90 330i
Guys.. How difficult is my question?!!***9786;***65039;
Old 02-23-2014, 12:41 PM
wilt wilt is offline
Mein Auto: 2011 328i
Visit Tire Rack web site and see if THEY think it fits!
Old 02-23-2014, 05:09 PM
Mein Auto: E90 330i
I did, but they have only the OEM sizes.
The options I'm asking about are custom sizes.
Old 02-23-2014, 05:24 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Phone Tire Rack tomorrow. I've had some good discussions with their sales reps. They have a good grasp of what does / does not work.
Old 02-23-2014, 05:37 PM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Measure the distance between the widest point of the top of the tire and the front strut on the inboard side, and also the distance between the widest point of the outboard side of the tire and the fender, while rotating the steering wheel.
Then, using the sum of these measurements, calculate the widest tire cross section that will fit. Keeping in mind that you may have to change the "offset" of the wheel if the two measurements are different. Of course that offset cannot be less than the OEM offset since this would cause the wheel to interfere with the brake caliper.
Old 02-24-2014, 07:12 AM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
Tire Rack told me that they did not recommend 245/45-17
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
Old 02-24-2014, 07:21 AM
Mein Auto: E90 330i
Thanks my friend. What about 255/40/17?
Really appreciate your help.
Old 02-24-2014, 01:12 PM
Princeton
Didn't ask that. Suggest you give them a call. They are very knowledgeable.
Old 02-24-2014, 01:38 PM
Mein Auto: '06 AW 330xi
Of course you can mount them, but why do you want a wider tire?
What benefit do you expect to gain with a wider tire?
It's unnecessary.
Old 02-26-2014, 04:52 AM
Mein Auto: E90 330i
My target is a little bit of ground clearance. In this case about 3mm
Old 02-26-2014, 06:33 AM
Ok well I wouldn't go up in tire sizes to get ground clearance. All you're doing is adding unsprung weight which may decrease your gas mileage.
If you're looking to add clearance in the front, you have the option to add a reinforcement plate. This should give you the clearance you're looking for in the front.
There isn't anything you can do about the rear besides maybe adding a helper spring. But I wouldn't do that....
http://store.bimmerworld.com/e36e46e...tes-p1219.aspx
http://www.turnermotorsport.com/p-27...ates-pair.aspx
Dinan also makes a plate. But we all know that you for the name with Dinan....
Old 02-26-2014, 07:12 AM
bear-avhistory's Avatar
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
I have 245X35X19 - 275X30X19" with no issues. A lot will depend on what width & back spacing the wheels have. My wheels are stock 19" 313's. You might not be getting a response because I would expect few people are going to 45/40 in larger tires
BTW: No response is better than one with a just guess or bad info.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/THP 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
