Old 02-22-2014, 02:11 PM
rsk rsk is offline
Mein Auto: 325i
non-RFT tire pressure
Hi group
Swapped my RFTs to Bridgestone turanza serenity plus non-RFTs this morning.
The size is 245/50/18. My question is... should I inflate the non RFTs to the same tire pressure recommended by BMW for the RFTs.
Thanks for your help
rsk
Old 02-22-2014, 03:07 PM
rajeek's Avatar
rajeek rajeek is offline
Mein Auto: ///M7
Yes, if they are the same size.
Sent from your mom's iPhone
Options: Executive Package, M-Sport, B&O Sound, LED Lighting, Drivers Assist, Active Cruise. No RWS (Rear Wood Shelf).
Mods: BMS n63tu Tune, PedalBox, H&R Sport Springs, RD Sport Front Lip, Rear Roof & Trunk Spoilers, 20" Forgestar F14 Rims, Akebono Ceramic Brakes, 20% Front/15% Rear Tint, Carbon Fiber Wrap, Smoked Taillights, 760 Exhaust Tips, "Golf Tee" mod, Kidney Grills & Front Vents Painted Gloss Black, Brake Calipers Gloss Black w/BMW Logos, B&W Carbon Fiber Roundels.
Old 02-22-2014, 03:14 PM
rsk rsk is offline
Mein Auto: 325i
Thanks Rajeek
Old 02-24-2014, 01:34 AM
ajdoha234 ajdoha234 is offline
Mein Auto: 2013 740Li
Originally Posted by rsk View Post
Thanks Rajeek
How do you like the ride difference?
Im really curious if the Non RTF's get rid of highway noise. My car seems louder than it shold be when Im cruising ( I usually hit around 110-120 mph) but I cant tell if its wind noise or tire noise.
Old 02-24-2014, 03:32 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
Please refer to this from Hankook Tires...
http://www.hankooktireusa.com/Serv/I...m=3&ChildNum=4
Though your non OEM tires may be the same size as your runflats, they are very different tires by design. Non-runflats perform differently, are less ridgid along the sidewall, and are usually much lighter in weight than runflats. Therefore, the correct inflation may be different in order to ensure that your tires' tread patch is correctly making contact with the road surface. I recommend doing a bit of research with the manufacturer to determine the proper inflation.
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 02-24-2014, 07:55 AM
rsk rsk is offline
Mein Auto: 325i
The ride quality is so much better. Now it feels like a luxury car.
Road traction is very good. Breaking has improved.
I bought the car 6 months ago and I did not enjoy the car until I dumped the RFTs.
The downside, drive without a spare. I have AAA and BMW roadside assistance and I am counting on that.
Cheers
rsk
Old 02-24-2014, 08:25 AM
rsk rsk is offline
Mein Auto: 325i
I read quite few forum on this subject and there does not seem o be a consensus on whether the tire pressure must be the same for non RFT as RFTs. I am going to call the tire manufacturer and see what they say.
That brings me to another question, my OEM tires were 245/50/18 on all 4 wheels and the recommended tire pressure are F:32psi and R:35 psi.
My new tires are of the same size as well. since all the 4 tires are of the same size, should I still use the recommended staggered tire pressure for front and back or use 35psi on all the 4s.
rsk
Old 02-24-2014, 08:44 AM
Leslierc's Avatar
Sejanus
rsk
You're saying that your non-OEMs are still stagered, yes? That's a good question. Off hand, I would say it's likely that it might still be differing pressures because of differences in size and weight-loads between the front and rear. This also would be a good question to pose to the manufacturer. It sounds like you're thinking in the right direction about this.
-Morpheus
Old 02-24-2014, 09:05 AM
Leslierc's Avatar
Sejanus
Cheers
rsk
I once owned two SC430s that came with the dreadful Dunlop run flats. I switched from the runflats to Michelin Pilots on the first SC430 and had my salesman tranfer them to the second SC when I got that one. From that point onward, my Lexus SA advised all his customers to switch from the Dunlop run flats to the Pilots. As you describe, it was a much different and better performing car with the change of tires.
-Morpheus
Old 02-24-2014, 09:10 AM
rsk rsk is offline
Mein Auto: 325i
Just spoke to the tire manufacturer and he said that I should use the recommendation from BMW and run 32psi in the front and 35psi in the back irrespective of whether RFT or non RFT.
For what it is worth, I filled Nitrogen in my tires to keep the pressure stable.
rsk
Old 02-24-2014, 09:20 AM
Leslierc's Avatar
Sejanus
rsk
Cool! Let me know how the nitrogen works for you. I'd be interested in how the tires behave with driving under different weather (temperature) conditions. I often check the psi on the tires on my Panamera and 991...the system actually communicates the pressure on each tire...and it's amazing how quickly the temperatures fluxuate under driving when the tires start out cold.
-Morpheus
Old 02-24-2014, 10:47 AM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is online now
Mein Auto: 2016 ///M5
Ain't that the truth. We headed out to church yesterday morning and warning light came on and said my back passenger tire was 31lbs. A few hours later, I go out to show a few homes and the light never came back on.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 02-24-2014, 11:38 AM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
I've always run my tires on the high side when it comes to air pressure. My last 7 still had lots of tread left when I traded the lease in. Currently with the M sport 20's I keep em at around 42 rear 39 front
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 02-25-2014, 08:10 AM
bruno787 bruno787 is offline
Mein Auto: 740Li (F02)
isnt that dangerous? overinflated tires have less traction
15 Maserati Quattroporte GTS
10 740Li (gone)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4
Old 02-25-2014, 10:29 AM
gassy gassy is offline
BMW 7 Series Obsessed
Mein Auto: 2011 750i Milano Beige
I run 38 rear/36 front on Conti Extreme Contacts non-RFTs. This is the best compromise between ride and tread wear for me.
2011 750i/ Milano Beige/ Saddle & Black Nappa/
Old 02-25-2014, 10:38 AM
chrischeung chrischeung is offline
Mein Auto: 2008 Mazda 6
It's air that supports the car, not the tires. So it make sense that the amount of air be the same. The rigidity of the RFT comes into play as support when there is a lack air, not at correct pressure, when the car is stationary.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 02-25-2014, 10:51 AM
Leslierc's Avatar
Sejanus
Interesting. So, what about this? I know that for non-runflats one can adjust the air pressure to effectuate ride and handling aspects. Performance tires specifically allow for this. For example, reducing the air pressure in a non-runflat will result in a tire wearing quicker but providing increased grip. The reason I didn't think that's possible for runflats is because a reduction in air pressure could compromise the integrity of the sidewalls.
-Morpheus
