Old 03-10-2014, 04:13 AM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
That tank looks pretty rusty and rust in a tank can't be fixed.... Bite the bullet and replace it with a good clean one! Dropping the tank is not really that big an issue - as long as it's nearly empty! Yes, the heat shield and tailshaft have to come off first.
Old 03-10-2014, 08:00 PM
Bonanzadave Bonanzadave is offline
Mein Auto: 1995 740IL
Thanks Mr Podmore, Thats about the only spot where the tank looks bad. Overall it looks pretty good. I would consider dropping the tank if I had access to a hoist but Im not a big fan of doing it in the driveway. If I did get it down it would only be for a repair cause a new tank is more money than I have into this car. Its too bad I cant even see the area where its leaking.
BTW: I went to the U-Pull yard and the 740 was gone. Most likely crushed. There were two new (97s) 528i's
I found these photos on a German BMW forum. Look familiar......
BMW BMW BMW BMW BMW
Old 03-15-2014, 02:41 PM
Originally Posted by chrisn7 View Post
I'm afraid you won't see much of the tank by removing the wheel arch liner, other than the leading top corner.
Yep, so I took off the RT rear tire and pulled back the wheel well liner. I was able to see the previous owner had applied some JB weld just above the seam. I scraped it off and saw 2 small holes. I scraped it pretty clean and then used a scotch brite soaked in Lacquer thinner. I applied some Poly sulfide which we use on aircraft fuel cells http://www.ppg.com/coatings/aerospac...90_class_b.pdf. Its a 2 part sealer that is really nasty. I have a heat gun running on it to keep it warm.
The saga continues.......
Old 03-22-2014, 09:16 PM
So far so good. No leaks
HTML code is Off
