E34 (1989 - 1995)
Old 02-23-2014, 04:51 PM
mgfranz mgfranz is offline
"You chose wisely..."
Mein Auto: E64, E38, Boxster, A4
"Key In Ignition" warning even when key removed
Hi all, new owner of a 1995 E34 here with a few issues. Like the title states, I get the Key In Ignition warning even though the key is removed. Is this simply a bad lock cylinder? I suspect the key is worn out as well due to the occasional sticking and inability to turn the key. I have tried spraying dry film silicone into the tumbler to no avail.
If I order a new lock cylinder, will it come as a duplicate key set, or will I have to have it re-keyed to match the door and trunk locks?
Old 02-23-2014, 06:53 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
I would try a new CCM (check control module) first. Sometimes they will display random errors and then it's time to replace. You could also check the resistors inside your existing CCM- there is a PDF DIY out there somewhere, possibly on Shoguns website.
Sent from my ADR6410LVW using BimmerApp mobile app
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 02-23-2014, 07:13 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Mine does this sometimes. Jerk the wheel back and forth until it locks, if that does not help put the key in and pull it out a few times while trying this.
Spray some WD-40 in it then get some graphite grease to free it all up.
Parts get dry/worn and do not move as they should.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
