Old 02-24-2014, 01:45 PM
Don Burgess Don Burgess is offline
Mein Auto: 1999 528i
Distance monitor/sensor for front of 328i
I just purchased a 2009 328i and want to know if anyone knows of an aftermarket distance sensor that can be mounted on the front of the car to help prevent running into parking curbs. The front bumper only has about 5 1/2 inches of clearance which is not enough for most curbs! I want something small, unobtrusive and elegant like the car itself. I have seen some stuff on the internet but they all require drilling holes in the bumper and running wires to a monitor on the dashboard. Yuk!!! In the meantime I will try to avoid curbs and park somewhere safe. Thanks.
Old 02-24-2014, 01:48 PM
Mein Auto: '06 AW 330xi
I just look in the reflection of the cars parked next to me to "see" the curb. Of course, this doesn't always work.
Old 02-24-2014, 02:13 PM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
You could also just pay attention.
I never understand why this is such an issue and actually comes up quite frequently. I am guessing your car isn't very long (compared to an SUV for example), no need to be on top of the curb. Leave a little space. Done.
Old 02-24-2014, 03:04 PM
Thanks. I'm sufficiently chastised now. All good advice.
Old 02-24-2014, 03:29 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
Amen, amen.
My daughter drove a '91 Camaro with a low front spoiler for 7 years and never dinged a curb or parking stop with it. All she had to do was pay attention. That spoiler was so low she even had to go across driveways at a diagonal to keep it from scraping...and she did just that.
And this technique is 100% free!
Well, seriously, I think you can manage this. But when others in the family borrow the car, you may have to have a little orientation briefing with them.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 02-24-2014, 07:04 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Have you noticed the right door mirror tips down
when in reverse so you can see the curb. The door mirror selection
switch determines if it does this I think it has to be in the left mirror
select position but its one of the other.
Old 03-01-2014, 11:13 PM
cbmw1200 cbmw1200 is offline
Mein Auto: 328i
I installed a curb-alert on my 328i and it works perfect. I get a few false alarms when the drive dips but still worth not destroying a $1500. front bumper.
Bought it from Southern Car Parts. $149.00
Charles
Carrollton, TX
Old 03-02-2014, 07:39 AM
wilt wilt is offline
Mein Auto: 2011 328i
Nice idea, if there were two sensors, one at each corner. When you park in the first diagonally oriented parking slot and ram one corner of the underside into the concrete wheel stop or curb and scrape, you'll see what I mean. Can't see the darn ends of the car sufficiently (even worse on E90 than my E46) to estimate distance from obstacles, and since I have only owned my E90 for two months I still sometimes stop too far back and stick out too far.
Old 03-02-2014, 07:51 AM
Thanks for the tip
I checked out the Southern Car Parts site and the Curb alert unit. It looks like it would work. There are lots of "how to" videos as well. When I know my car at bit better(only had it 4 weeks) I will consider it. For now I will just be very careful. What a great group of BMW owners. Thanks all! Bimmerfest rocks!
Old 03-02-2014, 12:01 PM
I just took the time to figure out that the visible portion of the hood disappears from my view 12-13" behind the actual front edge of the car...that ought be be easy enough to guestimate.
