Non OEM coolant expansion tank? - Bimmerfest - BMW Forums
Old 02-24-2014, 02:38 PM
sierrasmith71 sierrasmith71 is offline
Mein Auto: 2011 335i X
Yesterday I purchased a 2011 335i x drive. Clean and has new brakes and new tires.
On the drive home , (10 miles) I heard a "chime" and searched the unfamiliar dash to discover what need my attention.. I spied a yellow symbol that looked like a tank with water waves in it ? than it went out.. engine temp looked good --but who knew what the number meant? 240 F ( or so, I was trying to dive and decipher an unfamiliar dash) .. seemed too high for coolant , but ut was less than half scale , so I believe whatever it was would be OK..
While I was finishing my drive home I noticed a red triangle with an "!" in it ?? OK
Got home, turned the engine off and the yellow "tank" symbol appeared again. Time to read the owners manual..0n hour later . I discover that that I was being informed that the coolant was low and it need attention.. I noted the warnings not to open the filler until the engine was cool..
In the morning I opened it and found that the expansion tank is not as described in the manual. It does not have the floating red "bobber" but rather an internal white level gauge marked MIN and Max. An embossed diagram of a side view of this device was printed on the top of the tank with the word "KALT" highlighted..
Is this a non BMW tank that was added in a repair?
I searched and found no evidence a leak anywhere, and further searching on BMW forums seems to indicate that moderate coolant loss is not unusual ??
Thanks for allowing this long post, but I spent a bad night thinking "what have I bought?"
David Garrison
Old 02-24-2014, 02:40 PM
Mein Auto: '06 AW 330xi
My level is white. I know it's OEM. I've owned the car new, since 2006.
Post a picture.
Old 02-24-2014, 03:31 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
The owner's manual is rarely (if ever) updated to reflect running production changes for design fixes, parts changes and so on. Kalt is German for "cold," meaning, check the coolant level when cold.
Sleep well.
Oh, incidentally, the temperature gauge reports oil temperature, not coolant temperature (note the oil can symbol on the gauge). This is a much better indicator of true engine temperature than the coolant and 240F is about normal.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 02-24-2014, 03:33 PM
Coolant expansion tank 2011 335i Xdrive
here are some pics
David G.
ID:	424782   Click image for larger version
Old 02-24-2014, 03:41 PM
Zeichen311's Avatar
That's an OE BMW tank.
Old 02-24-2014, 10:40 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Wouldn't hurt to pay for a check up at the dealer or an INDY. Sounds like all is ok now though. These cars will throw up some warning lights every now and then but a restart usually clears everything up as sometimes you can drive the car too hard and it will protect itself and scream at you. Happened to me when I first got mine and was pushing its limits. Since then...nada.
Old 02-25-2014, 07:02 AM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
Keep an eye on the coolant level. It's probably nothing but coolant loss is one sign of a possible headgasket issue.
Old 02-25-2014, 07:07 AM
That's an oem tank. I've never seen one without the little bobber in there though
Old 02-25-2014, 11:22 AM
Zeichen311's Avatar
Mine is the same; perhaps it's a change that came along with the N55 engine.
Old 02-25-2014, 03:35 PM
Banned
Mein Auto: 2007-335 HTC
does the OP have to purge the system of air?
