Waterless car wash for spot cleaning? - Bimmerfest - BMW Forums
Old 02-25-2014, 02:51 PM
doak35 doak35 is offline
Mein Auto: E90 sedan (2008 328i)
I know there's been a bunch of discussion about this, but I have metallic black paint and am looking for something that's safe for spot cleaning my car in between full washes. Removing a bird spot, some pollen, water mark, etc.
It seemed that these products seemed to be best from what I read, so does any one have any experience with these or recommend something else?
Griots
Eco Touch
Optimum Opti Clean
I'd also heard good things about Optimum No Rinse wash, but that might be hard for me to use in my apartment's very tight parking area.
Also, I assume best way to apply any of these would be a good quality microfiber waffle towel? Anything else?
Old 02-25-2014, 07:15 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Spot Cleaning
For spot cleaning (and I do mean spot as in water spots or bird droppings), I keep a bottle of quick detailing spray in my trunk. For bird droppings, saturate the poop with the detailing spray then carefully loosen and wipe off with a microfiber cloth. You do have to be careful with this method to not scrape the droppings off as bird doo often contains sand and small stones which will scratch.
Unfortunately, pollen will blanket your car such that there is no such thing as spot cleaning it.
However, Optimum No Rinse with two buckets of water actually works pretty well and you don't need a lot of space to use it.
The detailing subforum has a ton of information about proper tools and techniques. Check it out!
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 02-26-2014, 07:29 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
This is what you want on Black Sapphire Metallic:
Name:	turtle wax black detailer.jpg
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-26-2014, 07:31 AM
Mein Auto: '06 AW 330xi
It's all safe for your paint but HOW you wash the paint is what matters.
Light pressure and straight lines only.
Don't go in circular motions! That's the #1 cause of swirls in your paint.
