Old 03-02-2014, 08:30 PM
Drewsome Drewsome is offline
Mein Auto: 328i
E90 to F30: wow!
I've been using dealer loaner -- 2014 F30. My car is a 2010 E90.
As to be expected, there are many differences in the driving experience. But one which immediately jumped out was that the F30 absorbed potholes and road irregularities FAR better than my car with OEM Continental RFTs.
The F30 has Michelin Primacy MXM4 tires on it. Can these tire be the reason for the much more civilized, less jarring ride?
Also, when I looked up these Michelins up on tirerack.com, they are NOT listed as RFTs. But how could this be? I thought BMW always puts RFTs on the 328i. If the Michelins are go-flats, then this might explain the smoother ride.
Would love to get this same road feel on E90 -- what do you guys think?
Old 03-02-2014, 09:10 PM
tturedraider's Avatar
Freedom isn't free!!
They're RFTs. The difference is newer generation RFTs and changes to the suspension.
www.bmwcca.org
Old 03-02-2014, 10:10 PM
MB330's Avatar
MB330 MB330 is offline
Mein Auto: 2006 330i
I drove few times my daughter 320i and must admit that this is fun to drive car with enough power (185hp) .
'16 320i Alpine White/Black/AT [ZDA, 494, 205, 459, 403]
Old 03-03-2014, 01:10 AM
gcreese gcreese is offline
Mein Auto: 2010 535i Sports Wagon
The F30 also includes a major change to the suspension. So while switching tires may help a bit, just changing the tires won't get you into F30 territory.
2010 535i xDrive Sport Wagon (April 2009): Deep Sea Blue / Cream Beige / Sport, Premium, Cold Weather Packages
2011 335i xDrive Coupe (April 2011, European Delivery): Le Mans Blue / Oyster-Black / M Sport, Premium, Convenience Packages
Old 03-03-2014, 01:54 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Any ideas what those suspension changes are...and whether they're a possible retro fit to the E9X?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Old 03-03-2014, 03:14 AM
Banned
Mein Auto: 2007-335 HTC
you could change the springs, if you can find a softer set, if thats possible
Old 03-03-2014, 04:07 AM
Chris90's Avatar
Chris90 Chris90 is offline
Mein Auto: '04 330i
Go Koni FSDs shocks and non-run flats. Should get you close to the F30's ride quality. Shouldn't have to change the springs.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 03-03-2014, 05:00 AM
captainaudio's Avatar
Worlds Foremost Authority
+1
I have the sport suspension with Koni FSDs and non RFTs. Better handling than stock and much better ride quality.
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 03-03-2014, 05:33 AM
Mein Auto: '06 AW 330xi
Springs mainly set ride height. You want softer shocks for a smoother ride.
Old 03-03-2014, 05:43 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
How many miles are on your E90 tires vs the F30?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 03-03-2014, 06:56 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
don't forget teh brand new bushings on all suspension parts that will have 0 clearance with metal parts.
Old 03-03-2014, 07:00 AM
floydarogers's Avatar
Pedant and Curmudgeon
One thing you may not have noticed is that the tires on F3x are slightly taller than on E9x. The E9x (typical common size) has 225/45R17, while the F3x has 225/50R17. All other tires on F3x are similarly a bit taller due to higher profile.
Old 03-03-2014, 07:17 AM
Chris90's Avatar
Mein Auto: '04 330i
Good catch, didn't know that. My E36 was 225/50R16.
Old 03-03-2014, 07:29 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
Have these on the 335D. They are great tires and do give a little softer ride (they are also great in the rain) but my guess is that it is the suspension changes to the F30. N4S
Old 03-03-2014, 07:38 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
It's way more than the tires. 225/45/18 Pirelli Cinturato's on my wife's 328i Luxury Line.
It's a bigger car, not to mention EPS and the 8sp AT make for a different driving experience.
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 03-03-2014, 03:48 PM
shadow 2 shadow 2 is offline
Mein Auto: 2011 335ix
Not for me. Way underpowered unless you like slow acceleration.
Old 03-03-2014, 04:32 PM
Yes, but I never said it was just tires.
BTW, on an E9x (actually the fronts on my 335d with sport package) the corresponding size would be 225/40R18.
Old 03-03-2014, 06:02 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
Think that Beach Ball under the hood is a thing of beauty....And love that the car turns off @ every traffic light & the IPad slammed in the dash is sweet.
Old 03-04-2014, 04:28 PM
Dubfound Dubfound is offline
Mein Auto: Audi
I actually just put these tires on my 2011 335. They are listed as ZP Zero Pressure. Same as run flats. I ordered them of tire rack and it was like $600 shipped with a $70 rebate in size 17". So fare they are great! They have a beefy sidewall and lip/wheel protector. Hang outside the wheel a good amount. Good in the snow and much smoother then the contis my car came with. The contis had about 30k miles on them.
Old 03-04-2014, 05:32 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I switched from Bridgestones to Michelins on my E93 and the difference was night and day, much improved ride - not as good as non runflats, but much better than the bridestones. It may not be all tire on the F30 that makes the difference, but a good set of runflats mill much improve it.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 03-05-2014, 05:52 PM
Mein Auto: 328i
E90 has 21,000 miles. F30 has about 2400 miles. So that's yet another variable. Good point.
Old 03-05-2014, 06:31 PM
thekurgan's Avatar
Bad Lieutenant
It's possible. I had noticed that as the run flats wear, they become noisy.
Ilse
Bruna
BMWCCA #453648
Old 03-05-2014, 07:06 PM
Mein Auto: 328i
It's not the noise; it's feeling every road joint up my spine. It's driving with my eyes peeled for the smallest of potholes, so I can weave around them.
Yeah, I get the whole connected-to-the-road, sports-car driving dynamic. That's why I bought this car, but the jarring ride is getting tedious. I'm ready to look for something I can do to make the ride more compliant while retaining crisp, responsive handling.
I'm leaning towards moving to non-RFTs as a start.
Old 03-05-2014, 08:07 PM
This is been discussed at length on this forum:
http://www.bimmerfest.com/forums/sho...ole+explosions
http://www.bimmerfest.com/forums/sho...e+captain+back
I live in Manhattan and I was able to solve the problem by:
1. Ditching the Run Flats - I am running Continental DWS non-RFTs
2, Replacing the dampers with Koni FSDs.
Doing those two things transformed the car (a 2007 335i E93 with Sport Suspension).
CA
BMWCCA
Old 03-06-2014, 05:58 AM
thekurgan's Avatar
Bad Lieutenant
Agree. No matter what people say, no matter what generation, run flat tires will never be as comfortable as a go flat; it's the price paid for convenience of not getting dirty.
Ilse
Bruna
BMWCCA #453648
