Inch pounds - Bimmerfest - BMW Forums
Old 03-03-2014, 12:15 AM
Bigrob126's Avatar
Bigrob126 Bigrob126 is offline
Mein Auto: 2010 328i Coupe Auto
Inch pounds
This seems like it should be easy, but I'm getting 2 different answers...so I am asking. Our oil drain plug requires 18 foot lbs of torque. My foot lb torque wrench is too long to maneuver, so I use my shorter inch lb wrench. I would think that inch pounds would be 10 times what foot lbs would be. Hence 18 foot lbs should convert to 180 inch lbs....and some websites agree with what I am saying. But some websites say that's not the case. One site says 18 foot lbs converts to 216 inch lbs. so which one is correct?
Rob
Old 03-03-2014, 12:27 AM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
Try using 1 to 12 conversion factor. Last I checked, there were 12 inches in a foot.
Old 03-03-2014, 12:30 AM
Dave @nz Dave @nz is offline
Mein Auto: E36 323 Msport, & E30 M3
Hi,
216 is the correct answer, the calculation is 12 inches =1foot therefore 18 ftlbs x 12 =216 inch pounds.
Hop this helps.
Dave.
Old 03-03-2014, 12:34 AM
Bigrob126's Avatar
Originally Posted by Dave @nz View Post
Hi,
Hop this helps.
Dave.
That makes perfect sense, so why am I using multiples of 10 and not 12?.....I don't know either! Nothing like over thinking an easy one! Evidently there are others think like me! Thanks!
Rob
Old 03-03-2014, 12:38 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well, I just checked, and I got 10" feet!
Now look, anE934fun, there's gotta be some leeway here. I'm a tall boy and most guys, certainly my wife, got less than 10" fer sure!
Old 03-03-2014, 12:42 AM
Uhhh, not that my wife's a guy.
Dammit! San Francisco....ya'll come out for the love parade. Dang! Another bit o'unintentional amusement. Can't say nuthin' tonight.
Old 03-03-2014, 12:49 AM
CitizenOfDreams CitizenOfDreams is offline
Mein Auto: 1998 BMW 740i
Because decimal units of measurement are much more natural for people who use the base 10 numeral system. One day Americans will realize that and do away with gallons/quarts (4:1), pounds/ounces (16:1) and miles/feet (5280:1, wtf?).
Oh, and get rid of degrees Fahrenheit while you are at it. And today is 2014-03-03, not "03/03/14". And the time is 02:48, not "2:48 AM".
Old 03-03-2014, 07:31 AM
///MyLittlePony's Avatar
///MyLittlePony ///MyLittlePony is offline
Outside looking in
Mein Auto: 2015 Mustang GT
The other way of doing it, according to a well known garage manager that frequents the boards is "finger torque", "wrist torque", "elbow torque" and "shoulder torque" depending on which muscles are engaged in the twisting...18 lb.ft is "finger torque". The torque wrench scale with the amount of touch you need. It is about 20ft.lb per joint closer to your shoulder.
[However, don't blame me if your sump plug falls out, drains all the oil and the engine seizes ]
[This should get the board juices flowing for a while]
My Little Pony
Old 03-03-2014, 07:37 AM
The most common method is "torque it till it strips, then back off quarter turn".
Old 03-03-2014, 07:57 AM
Chris90's Avatar
Chris90 Chris90 is offline
Mein Auto: '04 330i
You're a UNLV graduate I take it?
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 03-03-2014, 08:14 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
For a simple question of torque, this certainly provoked a lot of twisted replies.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 03-03-2014, 08:27 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
German/Austrian vehicle ownership has mad me OCD on torque. Doing work on my 335i and find that a lot of engine torques are between 7 and 15 foot pounds made me realize I can't tighten anything on it without a torque wrench. my muscle memory had me tightening everything to about 90 foot pounds. I have two SeaDoos and the problem is the same. Engines made in Austria and torques generally below 15 foot pounds however there is judicious use of expensive Loctite products. I don't see much requirment for that stuff in our BMW manual.
To answer the question though, it is a 1:12 conversion.
Old 03-03-2014, 08:42 AM
Ml3456 Ml3456 is offline
Mein Auto: E93 and F25
This post is sounding more like a 5th grade math lesson all the time!!
Old 03-03-2014, 11:30 AM
But then the bolt is stripped, and the whole exercise is useless.
Old 03-03-2014, 11:33 AM
You, your wife and a bunch of others (me included) don't have standard feet....
Old 03-03-2014, 11:35 AM
But the car's owner won't find out till after he pays the mechanic. So all is good.
Old 03-03-2014, 12:18 PM
Originally Posted by ane934fun View Post
but then the bolt is stripped, and the whole exercise is useless.
sarcasm
Old 03-03-2014, 12:59 PM
ashewb ashewb is offline
Mein Auto: 328i
huh, my deal extreme "tork toolz" read in fig newtons . go figure
Old 03-03-2014, 01:04 PM
DSXMachina's Avatar
Bimmerdex 7.4!
You forgot 'leg torque'. That's applicable to the crank damper pulley, and the front axle nuts on all-wheel and front wheel drive cars.
At one time there was another interval between shoulder torque and leg torque called back torque. OSHA does not allow us to use that any longer, and if we have to put on a brace we might as well just grab a torque wrench.
BTW, 18ft. lbs. (24.4 fig newtons) is wrist torque, not finger torque.
Old 03-03-2014, 01:43 PM
timthepug timthepug is offline
Mein Auto: 1998 subaru impreza
let me think on this for a moment
http://en.wikipedia.org/wiki/Moment_(physics))
Old 03-03-2014, 01:51 PM
Mein Auto: 328i
and only slightly related, given the situation in Crimea, can the nav be reset in "leagues " ? never know, could come in handy and there might be a new sweater in it .
Old 03-03-2014, 02:56 PM
You're givin' me Jaw Torque
Old 03-03-2014, 04:57 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
Only if you're taking the 3 series for a scuba dive
Old 03-03-2014, 06:26 PM
Mein Auto: 328i
nah, wasn't thinking 'bout 20k of em, maybe just a half of one at a time or 10. might be a neat hat in it too
Old 03-03-2014, 06:45 PM
ddeliber ddeliber is offline
Loving my d
Mein Auto: E350 & 2011 335d
Half a league, half a league, Half a league onward, All in the valley of Death Rode the six hundred.
