Old 03-03-2014, 09:05 AM
conceptosgroup conceptosgroup is offline
Mein Auto:
Can somebody what's the number in fuse board in x3 2010 lighter fuse not working can
Old 03-03-2014, 12:16 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
The fuse number varies by model and year. There should be a fuse placard clipped to the fuse panel cover. Post a picture of it and we can tell you.
Old 03-03-2014, 12:52 PM
Mein Auto:
Old 03-03-2014, 02:47 PM
Mein Auto: '06 AW 330xi
Pretty sure it's 47
Old 03-03-2014, 03:39 PM
Mein Auto:
Thank you!!
Juan Carlos Velázquez
Old 03-03-2014, 06:02 PM
Zooks527's Avatar
Originally Posted by fdriller9 View Post
Pretty sure it's 47
Yup, sure looks that way.
