Old 03-04-2014, 07:18 PM
tlfman tlfman is offline
tlfman
Mein Auto: 2007 328i
Original water pump or hoses?
I recently purchased a 2007 328i (105K miles) for my daughter. The interior and body look great and the engine looks and runs good but I do not have any service records for it. I plan to perform maintenance on it over the next few weeks covering all the essentials.
I am thinking about starting with the water pump and do a coolant flush. Before I do this, I am wondering if there is a way I can tell if it has been changed out already. Is there any specific labeling on the original hoses or the pump itself that could give a clue as to whether I should skip this task?
As I am a newbie....all help and comments are welcome...
Old 03-05-2014, 05:32 AM
Mein Auto: '06 AW 330xi
The water pump can fail as early as 20k or last over 100k. I wouldn't do the pump/Tstat as preventative maintenance on this car. It can go either way...
Mine died at 80k.
The only thing I can recommend is to check realoem.com and see what part number you have on the pump. Then compare that number to the ones listed on realoem.com. There were a few revisions of the pump so if you have one of the early part numbers, it might indicate that it's the original pump.
325i, water pump
