Old 03-05-2014, 08:48 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Today's 3'er Tire Inflation Trivia Question
Your 3 Series is on a lift (hoist to you Southerners) and the mechanic inflates all four tires to door jamb pressures. He then lowers the car to the ground so that all 3400+ lbs. is sitting on the tires. He rechecks the tire pressure.
What will the tire pressure be? You don't have to be specific, what's your guess? Does the pressure rise an insignificant amount? A few pounds? More than four pounds? More than 10 pounds?
Pointandgo, no fair you answering.
Old 03-05-2014, 09:08 AM
jeanlucdckhard jeanlucdckhard is offline
Mein Auto: 2012 E92 335i M-Sport
If I may ask this question here...
The sticker that says for speeds over 100mph.. the yellow sticker. That IS the minimum pressure I need to go over 100mph safely correct? It's autobahn time this weekend and I want to be safe and make doubly sure. Thanks!
Old 03-05-2014, 09:10 AM
spencers's Avatar
spencers spencers is offline
Mein Auto: 2006 330i
Seriously?
Tire pressure stays the same regardless of load or not.
Old 03-05-2014, 09:15 AM
Stevarino's Avatar
Stevarino Stevarino is online now
Mein Auto: 2008 335 / 2014 X-3
My guess
My guess is that the tire pressure will increase. How much, I don't know but my guess is just a few pounds.
Current Vehicles:
2017 440i Cv ED Sept 1, 2016 (ED #6)(PCD Oct 24)
2014 X-3 35i (PCD)
2008 E-93 335i Cv (ED #3) (Keeper)
BMW CCA #272524
Old 03-05-2014, 09:24 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Without looking at the other answers, I'll take a swing.
3400 lbs -> 850 lbs per wheel.
34 psig normal setpoint on my 225-45/17 tires. 8.9" wide / 78.5" circumference -> 700 sq.in of tire surface. 23754 lb(f) applied to inner tire surface. Increase load on tire surface from 23754 to 24604 lb(f) to pick up weight of car. 24604 / 23754 * 34 = 35.2 psig final pressure. Get the same result if you distribute the 850 pounds over the 700 sq.in. of tire surface (1.2 lb/sq.in.), so it seems to close.
So, I'd guess it goes up a psi or so. But I may be totally off base in force loading the tire.
Old 03-05-2014, 09:29 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 03-05-2014, 09:43 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
I'm guessing it will be fractionally lower because the tech's repeated pressure checks bled an appreciable volume of air from the tires.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 03-05-2014, 10:04 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
I agree.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 03-05-2014, 10:14 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Originally Posted by cwinter View Post
I agree.
You guys need to stop buying your pressure testers at Harbor Freight.
Old 03-05-2014, 10:16 AM
bbbuzzy bbbuzzy is offline
Mein Auto: '11 X3 xdrive35i
The pressure will be related to the volume of the chamber it is in (the inside of the tire) and the temp of the air in the tire. Assuming the tire doesn't change temp, then the pressure will remain the same unless the volume of the tire changes as the weight of the car is added . I'd guess there is a minor change in volume leading to a minor change in pressure (less than 1 psi). However, now I'm skeptical, since you might have started this thread because of a bigger observed change.
'11 BMW X3 xdrive35i
'05 Volvo XC70
'05 Sienna XLE Limited AWD
'06 330i (6MT, ZSP, ZPP) (retired)
Old 03-05-2014, 10:25 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
My initial reaction was to think an increase, but P=V/T says otherwise.
My vote is no change.
... Wait, how tall is the hoist? If over 10,000 ft I may want to reconsider.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 03-05-2014, 10:28 AM
cwinter's Avatar
Here comes trouble!
Actually, in my case, I need to buy a bigger garage where I don't have to squeeze in the corners to get to the valves on the passenger side, causing me to use the pressure gauge at a less than ideal angle. But point taken.
You know what the weather is like in NH, right?
Old 03-05-2014, 10:53 AM
DozerDan DozerDan is offline
Mein Auto: 335 d
Are we north or south of the equator. What is the current ATM pressure, did he use a oiled or oilless compressor. Was he wearing a red or green shirt when he fill? Same shirt when he lowered the car. What is the tire wear currently at....
Old 03-05-2014, 10:54 AM
cwinter's Avatar
Here comes trouble!
I would say that the weight of the car is what causes a change of volume in the tire due to compression of the tire on the road surface. The weight of the car as such is meaningless to the calculation, as it is simply the cause for the volume decrease that holds the air. Of course, higher weight causes higher change in volume.
With that said, on a properly inflated tire, the dispersion of volume will be very low, I'd assume just a few percent. Since pressure and volume are inversely correlated and temperature is unchanged, the change in PSI will be inversely proportional to the volume change.
I'd assume this is also not a linear relationship. That is, the volume change on a tire with 10 PSI vs 30 PSI will not differ by a factor of 3. I'd assume a highly inflated tire will experience almost no change in volume and hence pressure.
BTW, I tried modeling the contact patch of the tire as a circle and distribute the weight across that. I found that for every 0.07 kg/cm^2 the pressure rises by 1 PSI. Using that model yielded tremendous PSI increments (10+) per tire, which seems questionable.
Last edited by cwinter; 03-05-2014 at 12:20 PM. Reason: Fixed the correlation statement to show inverse relation, since p=t/v
Old 03-05-2014, 11:01 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Eh, I'll take a shot.
Guess on area occupied by tire on concrete with car rested: 3x6 = 18 sq.in.
Added stress = 3400 lbs / 4 / 18 = 47.2 psi applied to the patch of the contact area.
Now we find internal pressurized area of the tire and divide by 18 sq.in. then use as a factor on 47.2 psi = my guess is less than 10% change in pressure.
Old 03-05-2014, 11:07 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Well, if they were filled with NITROGEN ......
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 03-05-2014, 11:10 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Finally, some pertinent questions. Obviously the answer cannot be known without this information.
1025 millibars
oilless
blue (red or green? what country are you in?)
different shirt but same color, a slush ball fenderberg fell down the back of his other shirt (typical day in a NH garage)
50% tread life
Old 03-05-2014, 11:14 AM
DSXMachina's Avatar
Bimmerdex 7.4!
I'll wait until west coast lunch is over and respond. Someone got it dead right. But whom?
Where is Calwaterboy? How can we have a thread without Cal?
Old 03-05-2014, 11:33 AM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
lol Absolutely true too.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 03-05-2014, 11:43 AM
galahad05's Avatar
Better with Butter
Oh, and the pressure will increase a tiny bit I think. You increase the pressure on a gas, you squeeze it down until it pushes back enough to stop the squeezing. But in this case the tire itself will push out a bit due to the increased pressure.
That's my story and I'm sticking to it.
-- Irish Proverb
Old 03-05-2014, 11:55 AM
Zoomie94's Avatar
Zoomie94 Zoomie94 is offline
Mein Auto: 2013 335is E93
I agree with the "slight reduction in volume causes slight increase in pressure" camp.
Now whether or not your gauge has the precision needed to detect that slight increase in pressure is another matter.
2013 E93 335is / Blk/Blk/Al / 6MT / M-Sport / Nav / Cold Wx / CA / Premium / PDC / Recaro ProSPORT / Recaro Performance SPORT
2007 E93 335i / Blk/Blk/Al / 6MT / Sport / Nav / Cold Wx / CA / Harmon Kardon / Recaro ProSPORT / Recaro Performance SPORT / Koni FSDs (Sold)
1996 E36 328 Cabrio / Blk/Blk/Wood / 5MT / Premium / Butt Warmers (Sold)
Old 03-05-2014, 11:59 AM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
If any change were noted it would have to be attributed to "experimental error".
final answer: no change.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 03-05-2014, 12:03 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
I'm with Zooks ....... up 1 lb or so
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 03-05-2014, 12:31 PM
bmwrocks's Avatar
bmwrocks bmwrocks is offline
Mein Auto: 2011 328i Convertible
I cheated and looked this up. Because like most everything, this has been asked and answered before. This is what I found:
The equation you are looking for is the ideal gas law:
PV = nRT
P = Pressure
V = Volume of the container
n = The amount of gas
R = 8.314472
T = Temperature of the gas in the container
Solving for P you get:
P = (nRT)/V
In your scenario, you fill the tires and get a reading. You then put them on the car and read another reading. What has changed?
The amount of gas, R, and the temperature remain constant. (The temperature actually increases a little but that's not important right now.) However, the car slightly decreases the volume of the tire by deforming it. In terms of the equation, if V is smaller, P must be larger. Ergo, the pressure goes up.
2011 328i Convertible : Mineral White; Oyster/Black Dakota Leather; Premium, Sport, Value; Sport Wheel w/paddles; Heated Front Seats; Satellite radio; HK Sound
2012 528i Sedan : Titanium Silver; Oyster/Black Dakota Leather; Anthracite Wood; Comfort Access; Side & Top View Cameras; Cold Weather, Premium; Technology;
2004 330ci : Titanium Silver; Gray Leather; Premium, Sport; Fold Down Rear Seats; Xenon Headlights; Navigation System; HK Sound
2001 X5, 2009 528i (retired)
Old 03-05-2014, 12:32 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
I'll chime in later...
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
