Old 10-19-2004, 03:45 PM
fpa1974's Avatar
fpa1974 fpa1974 is offline
Learning to drive...
Send a message via AIM to fpa1974
Mein Auto: 02 M Cpe,03 325iT,05 330i
Question Cigarette lighter socket loose. How to tighten it?
So my cigarette lighter socket in the center console is loose (even if it does not get used for anything else except a portable air compressor ) in my car now. Basically you can spin it clockwise or conterclockwise for about quarter of a turn. Is it easy to tighten it down and does anybody know how to do that?
Thanks,
Florian
2002 M Coupe Estorilblau
2003 325iT Graygreen
2005 330i ZHP Imolarot II
368S/74
Old 10-19-2004, 03:55 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
Thanks,
Florian
Best bet would be to remove and replace. There is a key feature that keeps it from spinning. Somehow yours got sheared off. I have amber ones in stock and I can send you one with your shoulder belt pads, assuming I get to a point where they don't come out looking like guano.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 10-19-2004, 04:21 PM
fpa1974's Avatar
Do you have to get to the cigarette lighter socket from under the console to get it in and out or is there a way to replace it from the outside without disassembling the console?
Thanks,
Florian
P.S. I trust you the pads will be just fine
368S/74
Old 10-19-2004, 04:31 PM
Ron Stygar's Avatar
19,585 Miles
Keep in mind that it is powered with a hot at all times line.
Old 10-19-2004, 05:38 PM
Daver Daver is offline
Shake well
Mein Auto: 2003 325iT
The lighter-socket in my dad's coupe pulls out everytime he tries to unplug his cell-phone. I meant to have a look when I was visiting over the weekend... got busy with going to the races and stuff.
daver -- 2003 325iT
Old 10-19-2004, 06:41 PM
fpa1974's Avatar
Yes, I will disconnect the battery but can I replace it from above or do I have to mess with disassembling the center console?
Thanks,
Florian
368S/74
Old 10-19-2004, 06:50 PM
Ron Stygar's Avatar
19,585 Miles
Thanks,
Florian
You just have to pull the fuse.
I've removed mine from above but destroyed it in the process.
You also have to clip on the light part from behind.
Old 10-19-2004, 07:15 PM
mng's Avatar
mng mng is offline
Mein Auto: E39
can probably get to it by just removing the shift boot and the foam thing under there...
Nick aka mng
2003 540i/6
intro/clean up thread
Old 10-19-2004, 07:28 PM
fpa1974's Avatar
Good idea!
Thanks,
Florian
368S/74
Old 10-19-2004, 07:36 PM
fpa1974's Avatar
Ron, do you know what fuse I have to remove?
Thanks,
Florian
368S/74
Old 10-19-2004, 07:42 PM
Ron Stygar's Avatar
19,585 Miles
Ron, do you know what fuse I heve to remove?
Thanks,
Florian
On my car it is 30A Fuse 32 (green).
The fuse chart is on the bottom of the fuse box cover.
Old 10-19-2004, 08:10 PM
fpa1974's Avatar
Thanks,
I will make sure it is the right one on mine too.
Florian,
368S/74
Similar Threads
Cigarette lighter pops into lap when hot! Kurt Martin E36/7 Z3 (1996-2002) 14 05-03-2003 05:50 PM
Cigarette Lighter Socket Jumper Cables? 2001E46 General BMW Questions 1 04-24-2003 05:47 PM
Cigarette lighter inoperable ZIGGURAT89 3 Series & 4 Series 7 01-14-2003 07:31 PM
Radar detector plugged into lighter socket NJ330Ci General BMW Questions 2 01-28-2002 09:42 AM
