Old 03-05-2014, 01:02 PM
laura90 laura90 is offline
Mein Auto:
Blown head gasket
Why does it cost so much to change a blown head gasket? And which ones do you guys recommend
Old 03-05-2014, 03:22 PM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
A head gasket is a MAJOR undertaking in any vehicle.
Old 03-05-2014, 03:35 PM
timarnold timarnold is offline
TA
Mein Auto: 2003 bmw 525i 2005 X3
Assuming you are asking what type of Head Gasket to use, it's really best to stick with OEM. It is probably an 8 hour job plus machine shop time (& expense) to machine the head.
Old 03-05-2014, 03:44 PM
White94RX White94RX is offline
Mein Auto: E39 540
Eight hours? Try at least double that. And that's assuming your aluminum block holds up to re-torquing the heads. Every aluminum block gets tested before we even pull the head off. Break the head bolts loose, and retorque. About 75% of them won't hold. Pulls the threads out of the block. Then its new motor time. Or someone with the proper equipment could theoretically drill it and put in a helicoil. The older engine (early m52, or maybe all m52?) had a cast iron block and that wasn't an issue.
BMW Level 1 Master Certified
2001 BMW 540i
Old 03-05-2014, 07:19 PM
Mein Auto: 2004 X3 2.5i
Did I miss something? I thought your only problem was a non-functioning radio?
Hopefully you mean valve cover gasket and not head gasket?
In which case an Elring Klinger might be the same as a genuine BMW one. Not sure.
Victor Reinz is another possibility. I wouldn't use any other aftermarket ones though.
Old 03-05-2014, 08:41 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
An 04 2.5 is M52.
Watch that temperature gauge folks. Hot means stop.
Old 03-05-2014, 09:14 PM
Originally Posted by joylove View Post
An 04 2.5 is M54.
Typo corrected.
Old 03-05-2014, 10:05 PM
thanks, jet lagged
Old 03-06-2014, 02:13 PM
Mein Auto: E39 540
Do NOT use victor reinz gaskets. They leak even when new
2001 BMW 540i
Old 03-06-2014, 05:42 PM
Mein Auto:
Lol yeah that was one issue and now after fixing my thermostat water pump and expansion tank turns out there was coolant in my spark plugs and so it's now the head gasket
Old 03-06-2014, 05:44 PM
Mein Auto:
Thanks for the heads up
Old 03-06-2014, 06:13 PM
Mein Auto: E39 540
No problem. I've replaced several of them when they didn't last even a few hundred miles before they leaked again. I wouldn't use anything but BMW OEM for gaskets. And make sure you or your mechanic replaces the 15 rubber sealing grommets or it will still leak!
2001 BMW 540i
Old 11-20-2014, 04:46 AM
dvdgry dvdgry is offline
Mein Auto: 328i
What is the average price for this fix diy vs taking to a mechanic?
Old 11-20-2014, 08:02 AM
Flat-rate time appears to be 2.5 hrs., so with approx. $90 O.E. parts (incl. the 15 grommets) about $450 + tax at dealership, $375 at independent, and < $100 DIY.
For DIY you have to decide if using a small amount of sealant in key areas is the right thing to do. No sealant used at factory, some BMW manuals say use it, some say not, and no agreement on which type of sealant.
