Old 10-19-2004, 05:38 PM
PeteG PeteG is offline
Mein Auto: '01 X5 3.0i, '97 Z3 2.8i
Winter storage/battery question....
This will be my first winter with my '97 2.8i (I am second owner, car was never out in winter). I will be putting the Z in a rented garage for the winter. Such is life in Maine-good thing for the X5!
Should I:
A) remove battery altogether?, or
B) Leave battery in with a battery tender?
If answer "B", should it be the BMW battery tender that roadstersolutions.com sells, or can it be one from my local auto parts store? TIA.
Old 10-19-2004, 06:54 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
I would say B and I would get the one from leatherz.com
as opposed to soulutions
Old 10-19-2004, 07:42 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
The battery tender we sell is the Battery Tender Jr. Costs less than the regular battery tender and works just as well. BMW uses Battery Tender also, but with BMW label on it.
Jon Maddux
10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe
Old 10-19-2004, 08:12 PM
goldenpaw goldenpaw is offline
Arrow
I also will be storing my newly acquired 2001 Z3 3.0... Heated indoor facility. The manual states to inflate the tires to 51PSI...assume to prevent flat spots...but is this correct, or are there better solutions??
Any other steps I should take??
Mark
Old 10-19-2004, 09:04 PM
01silber's Avatar
Im here
also before start up after it sitting all winter, drain the oil, pour in fresh so it coats everything before start up, you have to do that to be a member of the z3 anal retentive club
Old 10-20-2004, 01:28 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
1) for long term storage, change the oil just before storage, then run until hot. This is not needed for most winter storage (Montana and Alaska may be exempt ).
2) Use a battery tender, even if you remove the battery, the battery will discharge over time.
3) Inflate the tires to 50 psi plus to reduce flat spotting, or get a set of the storage devices (you lay them on the floor and drive onto them).
4) Fill the tank to reduce the possibility of condensation in the tank. You can also use some gasoline stabilizer, but I don't think this is needed for most winters (a few months). You would add it to the tank and fill the tank, then drive home, which wil distribute it throughout the fuel system.
5) DO NOT run the eninge for short periods during the winter. LEAVE IT ALONE, unless youa re able to drive it loong enough for the engine to get fully up to operating temperature thoughout the engine. And it must be driven to do this.
I disagree that adding oil will "coat everything with oil". For serious long term storage use a storage oil, and FILL the engine up to the very top. Squirt a generous amount into the cylinders. Remember to drain the storage oil before starting and fill with normal oil.
If you didn't do anything special and the car has ended up sitting, pull the plugs, squirt some oil in (about a tablespoon) and crank the engine with the plugs OUT untl you get oil pressure or the warning light goes out and then a few seconds more. This distributes oil to the bearings withou inducing any load. Then replace plugs, start adn run, get up to operating temperature and then change the oil.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 10-20-2004, 05:15 AM
sthoma9's Avatar
sthoma9 sthoma9 is offline
Mein Auto: 2001 Z3 3.0i Coupe
my 2cents
i also do the following-
· place a box of baking soda inside the car to reduce the stale/musty smell after long periods of storage
· place moth balls around the car to keep rodents from moving in
· cover the exhaust pipes (extra measure against rodent intrusion)
S.S.T.
'01 BMW Z3 3.0i Coupe- for fun
'91 Lexus LS400- daily driver
'03-'06 F-250/350 PS- for work
'97 BMW M3/4- sold
Old 10-20-2004, 05:25 PM
Pinecone's Avatar
M Mad
I prefer to shoot rodents across the garage on first start up. A good healthy one makes good enough seal to REALLY pop out of the exhaust.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-24-2004, 08:52 AM
Alex Baumann Alex Baumann is offline
Ex-Dictator
Mein Auto: Saab
Is anyone using Battery Tender Plus ? I'm considering to buy one to use it in the Alpina. Is it conditioning the battery too ?
Any feedback is appreciated.
"Effective leadership is not about making speeches or being liked; leadership is defined by results not attributes."
Old 12-25-2004, 06:01 AM
Pinecone's Avatar
M Mad
I have both Battery Tender Plus and Battery Minder units. For conditioning the Battery Minder is better. It has some features to help reduce sulphation of the plates.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Similar Threads
How important are winter tires in the winter? tpetty 5 Series 35 08-02-2004 12:02 PM
Which snow tires should I get? SizzlerMA Tire Rack's Tires, Wheels, Brakes & Suspension 25 01-30-2004 05:12 AM
Winter season sort of question... coldheat General BMW 2 12-03-2002 08:48 PM
Winter setup tire sizing questions AlexM520 3 Series / 4 Series 5 11-03-2002 03:58 PM
