Old 03-07-2014, 11:21 AM
gixman gixman is offline
Mein Auto: 2008 BMW 535xi
Diff Fluid Change
Has anyone changed there diff fluid lately? What fluid do you guys recommend? 75w90 Red Line, Castro, Motul?
I was hoping to find a kit with the drain/fill plugs with the o rings but I can't find one.
Does this look like the right drain plug?
http://www.ecstuning.com/ES205597/
2008 535xi
Performance: PTF Custom Tune - Jake, AR Design Catless DP's, ER Intercooler, ER Charge Pipe, Forged Motor sports DV's, BMS DCI, Wedge Sport Flash/Coding
Suspension: KW V3's, UR Strut Tower Brace, UR Lower Strut Bar, M5 Pull Rods, RD Sport Sway Bars
Exterior: VMR VB3's 19's with Conti DSW’s, MTech front bumper, HID fog lights, Umnitza ICE LITE Angel Eyes, Clear LED Side Markers, Osram Xenon D1S 6000k headlights, OEM Gloss Black Kidney Grills
Old 03-07-2014, 11:48 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Yes, 33117525064
http://realoem.com/bmw/showparts.do?...93&hg=33&fg=10
Old 03-07-2014, 12:43 PM
Great. Thanks. I assume both diffs have a drain and fill plug so I will order 4. I'm going to go with the Motul 75/90.
2008 535xi
Old 03-07-2014, 12:50 PM
OEM Fluid is %0 buck for .5 liter! http://www.ecstuning.com/Search/Site...luid/ES197413/
2008 535xi
Old 03-07-2014, 02:14 PM
flipwils11 flipwils11 is offline
Mein Auto: '80 M535i, '12 M3, '04 xi
I used Redline 75w90.
I bought fill and drain plugs for the job on my 6spd 550i but only one had a drain plug. Can't remember which though, trans or diff?
Old 03-07-2014, 02:27 PM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
Originally Posted by gixman View Post
You're looking at the wrong fluid unless you've got an M LSD in your car. This is the link to the OEM fluid (Castro) and it's $19 / liter:
http://www.ecstuning.com/Search/Site...uid/ES2562683/
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 03-07-2014, 02:53 PM
DIY'er
Transmission has a plastic drain plug built into the oil pan + fill plug further up, I believe it was metal
Diff should have both as well, probably both metal plugs. Well, since these are BMW's, who really knows
Old 03-08-2014, 06:15 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Make sure you remove the "Fill" plug first: if the drain plug is removed and then the fill plug can't be removed you're screwed.
Old 03-08-2014, 11:57 AM
Thanks for the feedback.
I ordered Royal Purple before I left work on Friday before I left work. Didn't see the Castrol link. The RP has the friction modifier. Is this fluid ok to use?
http://www.ecstuning.com/ES263484/
I also will change the transfer case fluid. http://www.ecstuning.com/ES2515438/
And I ordered 4 plugs just in case because I'm not sure if both Diffs have a drain and fill.
2008 535xi
Old 03-08-2014, 09:11 PM
rokdok rokdok is offline
Mein Auto: 2005 545i
I did mine a few weeks back. Bought fluid from LandRover dealer (same as bmw fluid just a different package). Replaced the drain plug with a magnetic plug. Easy job!
RokDok
___________________________
2005 545i - 137k Miles
Work Done (but not written up):
With a lot of help a Professional Mechanic:
- Engine Removal, Teardown, and Installation
- Cylinder Heads Valve Seals / Valve Lapping, Bank 1 - Eccentric Shaft / Intermediate Levers
- Replace Gaskets and Seals, Timing Guides
With a lot of swearing:
- Alternator Bracket Gasket, Brake Booster replacement
Old 03-09-2014, 12:32 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Any full synthetic Differential oil 75W90 should works. I used Castrol Syntrax Manual 75W90 before and now replaced with another local supplier in AU to Penrite PRO GEAR 75W90. They both work fine.
Once you drain the differential, if you have any spare oil left, then flush the system with filling and drain plug open with fresh 500ml fluid (usually if you do this regularly, you will have that much left from the last service, I had 800 ml left). Then plug the drain plug and fill it up with fluid.
Good luck.
Old 03-09-2014, 08:56 AM
Thanks. Do you hand the torque specs for the drain/fill plugs?
2008 535xi
Old 03-09-2014, 09:44 AM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
For both plugs with sealing o-ring torque spec is 65 Nm or 48 ft-lb.
If you have the old style plugs without o-rings it is suggested that you replace them. If you don't the torque spec is 60 Nm or 44 ft-lb.
Old 03-10-2014, 07:22 AM
Rokdok,
Where did you purchase the magnetic drain plug?
2008 535xi
Old 03-10-2014, 07:23 AM
thanks
2008 535xi
Old 03-17-2014, 05:34 PM
I decided to change the transfer case fluid first because the fill plug was hard to get at. What a PITA. It is covered by a heat shield and I needed to drop the exhaust a few inches just get at it. Even with the heat shield removed there is limited space. I had to borrow a tool a tool from my friend or you can make one. You need a stubby piece of 14mm hex key(you need to cut it) and a angled open end wrench. I plus was I discovered my DP gaskets had a small leak so I replaced those as well. I also installed RD Sways and did a drain/fill on the coolant.
I didn't have time to get to the Diffs. The front Diff has a drain and fill plug and there is access to the fill. The rear diff has one drain/fill plug so you need to use suction to get the fluid out(remember I'm talking about a 535xi, other models may be different). I thin I'm going to send the Royal Purple back to ECS and order the OEM Castro that DJToad pointed me to.
2008 535xi
Old 03-18-2014, 06:38 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
my experience with the old xfer case, the fluid is dirtier than the rear-diff. So I think you did the right thing to do xfer case first.
I haven't replaced my rear-diff, the only fluid that still original in my car, cause the there is no drain plug so you right you need to use suction device with a hose to drain/fill.
BTW, to whom has done the rear-diff, was the fluid looked bad? like alot of metal shaving, burned etc?
Old 03-18-2014, 07:29 AM
I found a site that sells magnetic drain plugs for the diff's/transfer case. Too late for the transfer case for me but I may buy 2 for the diffs. They don't use the rubber O ring though and they are 35 bucks a pop.
http://www.drainplugmagnets.com/bmwautomobiles.php
2008 535xi
Old 03-18-2014, 02:57 PM
kskane's Avatar
From DownUnder
For the diff drain/fill plug, you can actually replace the O-rings on the old plugs itself instead of replacing it. Just do a search on ebay for Diff/Differential O-rings.
Old 03-18-2014, 07:56 PM
I purchased the Magnetic plug at Bavarian autosport:
SS M22X1.5 Magnetic Drain Plug - Differential - Dimple 2005 545i - $31.95
New fluid (Left) and old fluid (right) - This is the fist change at about 136,000 miles. No signs of metal and it didn't smell burnt either. Just darker!
Rock
Name:	Differential Fluid Change.jpg
Old 03-19-2014, 06:53 AM
Rock
Thanks.
That seems consistent to my finding when I changed the diff fluid on my X5, so it's not higher priority to me compare to trans fluid or even xfer case fluid.
Old 03-23-2014, 03:45 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
OK if I understand correctly for an e60 non-M I do not need the friction modifier, just use 75W 90W gear oil which I believe is a ML-5. Is this right.
Old 03-24-2014, 11:49 AM
I beleive that is correct.
2008 535xi
Old 03-24-2014, 01:11 PM
Jaystyles's Avatar
Jaystyles Jaystyles is offline
Mein Auto: 545i Sport
Got my diff fluid at my indy and what a difference...The car feels so much smoother and has a little more pep. Its not a placebo effect. Highly recommend getting this changed.
Old 05-12-2014, 08:25 AM
wallstreetblues wallstreetblues is offline
Mein Auto: BMW 530i
Gear oil change
I have a 2006 530i petrol, I was wondering if someone could guide me as to what is the frequency of gear oil change and more specifically in my case as the gear oil has not been changed since its manufacture.
The vehicle has done 15000 miles and driven very sparingly
Best Regards
Asif
