Abs question - Bimmerfest - BMW Forums
Old 03-08-2014, 01:37 PM
J750il96 J750il96 is offline
Mein Auto: 96bmw750il 79 928 porsche
Abs question
I took the wheels off today so I can check my abs sensors and found a wire on the right side hanging there but not sure where it goes and a plug above a black box
I have some pics
Old 03-08-2014, 01:45 PM
More pics
Abs rt side
Old 03-08-2014, 02:21 PM
jmorgenson jmorgenson is offline
Mein Auto: 1998 BMW 740iL
So in the black box, you have 2 cables. One is the ABS sensor cable and I'm guessing the other is a brake pad wear sensor cable (not sure since I've never had a 750).
The other end of the ABS cable will screw into the rear side of the wheel, basically the opposite side of the brake disc. If the other cable is a brake pad sensor, then it will attach to the brake pad inside the caliper.
Old 03-11-2014, 03:57 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
If Jmorgenson isn't right he should be. That is my guess also. Are you getting any displays for ABS or Check Brakes?
Old 03-11-2014, 04:26 PM
I couldnt tell untill yesterday because i replaced my cluster and what came up on my display was [ check brakes ] and [ check brake lights ]
the brakes are because of that break pad sensor wire and im not to sure about brake lights because they all work. i had a check coolant come on but i topped it off with distilled water and it went out. i have clear antifreeze in the rad does anyone know what brand antifreeze comes clear ?
QUESTION does anyone know how i can program the correct milege on my new cluster
. the car only has 90k but the new cluster reads 217k. i was told to go to the dealer with both clusters and they can program the milege into my new cluster is this true ?
HTML code is Off
