2001 740il heater valve - Bimmerfest - BMW Forums
Old 03-11-2014, 12:10 AM
01740 01740 is offline
Registered *****
Mein Auto: 740il
Even though spring is approaching is it important for me to replace my heater valve ?
Old 03-11-2014, 03:43 AM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
Well, if it is leaking, or you are not getting heat when you want it ... why would you not replace it? Is there a reason you'd wait until the next time your windshield is covered in ice and you only then decide you'd like to defrost it?
Old 03-11-2014, 06:34 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Unless you have the auxiliary heater fitted (uncommon), the valve has no function other than to supply heated coolant to the driver and passenger side of the heater matrix, , so its not critical if its not working over summer. You may not need to replace it though, they can be re-built if not excessivley corroded, and parts are readily available via ebay
Old 03-11-2014, 08:01 AM
Registered *****
Mein Auto: 740il
Thanks very much, if its not leaking I think ill wait until the fall to replace it
Old 03-12-2014, 05:24 AM
Mein Auto: 750iL
Replace? - when you see the price, you'll look at a rebuild....
Old 03-12-2014, 05:28 AM
Registered *****
Mein Auto: 740il
I do most of my work myself so I wont be paying anyone for labor
HTML code is Off
