Wheel spacer size advice - Bimmerfest - BMW Forums
Old 03-11-2014, 03:50 PM
apache15 apache15 is offline
Mein Auto: 2013 E93 Convertible
Question Wheel spacer size advice
Hello everyone. I'm ready to order spacers for my e93 convertible stock wheels 17" and would appreciate some advice on how wide to go. I would like the wheels to come out flush or just inside the wheel well. I'm thinking 5mm in the front and 16 in the rear?
ID:	427519   Click image for larger version
ID:	427520   Click image for larger version
2013 E93 328i Convertible - Jet Black on Oyster/Black Dakota/Bamboo Anthracite, Prem, Cold, Bluetooth, Nav, iPod, Comfort Access - nickname "KitKat"
Old 03-11-2014, 04:13 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I don't have a good answer for you, but I did find some photos, some of the links may point to some pages where specs are noted:
https://www.google.com/search?q=bmw+...hp%3B500%3B400
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 03-11-2014, 05:08 PM
Old 03-12-2014, 06:26 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
The size you require will depend on wheel and tire type. Only foolproof way is to measure. Here's a guide:
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Old 03-12-2014, 09:00 AM
Go Navy Go Navy is offline
Mein Auto: 2011 BMW 328i Sedan
Here in Taxifornia, there's a law about that (and nearly everything else). It prohibits tires from protruding beyond the wheel well, if I'm not mistaken. But you're not in Taxifornia, although New Jersey isn't exactly the Land of the Free either.
2011 E90 328i, Nav, Premium, 6 spd Steptronic, Tasman Green, Beige Dakota Leather.
2006 325Ci, Premium, Blue, gray leather, Steptronic.
Old 03-12-2014, 10:11 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
With hi-def cameras in every police car, if your wheels protrude over 1mm, a policeman will stop you and, on verifying your identity, become bellicose as a negative reinforcement.
Thereafter, after review by a California psychologist, you will periodically be checked for compliance, and additional negative reinforcement applied until your compliance is verified. If you do not comply within their 'timely manner' guideline, after-compliance neg reinforcement is applied as often as necessary to impress upon you the importance of obedience re: anything they wish.
As all vehicles are tracked by license plate readers here, when matched to your cell phone location, an officer can be dispatched for a psych conditioning stop as they are available.
For the good of all, Obama wishes to implement this nationwide....venues are many! Control of your health, vital to every serf, was a huge step.
Old 03-12-2014, 10:52 AM
Yes, Calwaterboy, I think your description is frightening, Orwellian, and accurate. I've heard a rumor that the 5th stage conditioning is waterboarding, and as a result, there is no 6th stage conditioning. Don't forget to turn in all your plastic bags, water pistols, and e-cigarettes. You don't want to get caught with any.
Old 03-21-2014, 10:33 AM
Angry Wtf
Decided to play it safe and get ECS 5mm and 15mm rear, take it to my BMW dealership and they tell car is shaking and rattling. I call other dealer nearby and they tell me you can't put spacers on a stock wheel. Is this true??
Old 03-21-2014, 11:21 AM
OregonDonor OregonDonor is offline
Mein Auto: 2011 328i
Not true as long as you purchased hubcentric spacers.
Old 03-21-2014, 01:57 PM
Phil325i's Avatar
There's no such thing as a hubcentric 5mm. They're too small and allow the remaining portion of the existing hub flange to be used. AFAIR hubcentrics start from 10mm upwards...
Old 03-21-2014, 02:08 PM
ModBargains III ModBargains III is offline
Mein Auto: E92, E82, E46, E39
you are correct Sir!
Sean Singh | Modification Expert | Sean@modbargains.com | (714) 582-3330 ext. 8009
BMW Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
AE Performance | Remus Exhaust | BMW Performance Exhaust
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog!
Old 03-21-2014, 02:10 PM
typical dealership nonsense
you can use spacers on stock wheels
the question is what spacers to use...
we recommend hub centric spacers with extended bolts.
in the case of smaller sized spacers like a 5mm i have used them before and never had any issues....
Check out the Blog!
Old 03-21-2014, 07:43 PM
Exactly. The one dealer (Prestige of Ramsey) couldn't do it. Then I go to Park Ave and they said it can't be done. I was like WTF
e93 convertible, wheel spacers
