Old 03-11-2014, 08:55 PM
commandervp6 commandervp6 is offline
Mein Auto: 90 BMW 525i
May I present symptom(s)
I have a 97 BMW 740il and the only symptom I have honestly is it stalls after starting once in a while. The check engine light is on also. I read the code and can't remember other than it had to do with camshaft position sensor, might not have had a number code or just generic. Aside from what I have heard, what is the probable issue, crankshaft or camshaft position sensor in terms of what is more common with these? Looks like the camshaft is 3X the cost of the crankshaft position sensor, in California..
Old 03-11-2014, 10:05 PM
sigtwenty sigtwenty is offline
Mein Auto: e38
Maybe read the code and report back......let's not speculate and throw parts theory at it
Old 03-11-2014, 11:06 PM
CitizenOfDreams CitizenOfDreams is offline
Mein Auto: 1998 BMW 740i
+1, read the code, and don't swap any parts until you do.
Having said that, I once left my camshaft sensor unplugged and got the same symptom: starts and runs fine, but sometimes dies after starting the engine and putting the car in gear.
Old 03-12-2014, 09:00 AM
Cleaning CPS
Is there any truth that cleaning the CPS solves any issues, I have bought the part already and they are pretty easy to put in, I will check that pin 1 & 2 have a steady 490 ohms first.
Old 03-12-2014, 09:26 AM
You are confusing crankshaft sensor (which is a simple inductive coil) and camshaft sensor (which is an active device based on a Hall sensor). You will not measure anything like "490 ohms" on a good camshaft sensor.
Old 03-12-2014, 05:13 PM
Thanks for clearing that up
So how do I test the camshaft sensor, is the burning question?
Old 03-12-2014, 05:22 PM
INFAMOUS FAME INFAMOUS FAME is offline
Mein Auto: 1997 740I
Try maf sensor thats what i had on my 97 installed new maf and it cleared all my misfires and camshaft codes .best to run the codes on it first before you go replacing things
Old 03-12-2014, 07:02 PM
The easiest way I can think of would be looking at pin 2 with an oscilloscope on a running car.
Do you have a particular reason not to trust the OBD codes?
Old 03-12-2014, 10:10 PM
Mein Auto: e38
Post the codes!
Old 03-13-2014, 11:04 PM
I traded it away for a 95 318iA!
Bought an aftermarket cps, installed it and it wouldn't even stay running as long, worse than before. I ended up trading it away so I will never know.
Old 03-14-2014, 12:16 AM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
I guess the advise of pulling codes by members aren't suffice. Throwing parts at it sure won't fix it
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 03-14-2014, 02:19 AM
Misunderstood
I appreciate all the advice. The car was traded for different reasons. My mechanic does think that it WAS the cps because of it running worse with an "aftermarket" than the one currently installed "oem" and the advice is appreciated.
HTML code is Off
