Old 03-11-2014, 09:01 PM
Chuck F Chuck F is offline
Mein Auto: Z4 3.0I 2006
Passenger window/ power roof
When I close and hold the power roof button it will close the drivers side window, but not the passenger. It will close if I use the side button for the passenger side. Any ideas?...thanks. 2006 Z4
Old 03-12-2014, 05:24 PM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
have you tried to reset the window regulator? Operate the passenger window, run the window down and keep pressure on the switch for 20 seconds, then run the window up and keep pressure on the switch for 20 seconds. this procedure should reset the regulator limit up and down.
Old 03-14-2014, 02:23 PM
Window
Thank you, does it matter if I use the drivers side control for the passenger window or the passenger control only.
Old 03-15-2014, 07:35 AM
imz4n's Avatar
Z ENTHUSIAST
using this process will work to reset from either side, no difference.
