Old 03-12-2014, 02:09 PM
Robert A Robert A is offline
Mein Auto: BMW 535d
Various Questions on my 2014 535d
A grabbag of questions on my 2014 535d:
1. If I have been shifting manually and the shift lever is in M/S, is there any shortcut out of manual mode without having to move the shifter back to D first?
2. Does anybody really understand how the Mode button affects the Sport Auto transmission? AFAIK, it has no effect whatsoever. The faster shifts and the higher shift points are a function of where the shifter is placed. What am I missing?
3. Is there any way to adjust the sensitivity of the auto headlights without recoding or going to the dealer?
4. My steering wheel is about 5 degrees to the left. It was delivered this way and I know it's not the crown in the road. I'm curious if anyone else had the same thing. I'm bracing for the inevitable fight with the servicing dealer.
5. I have a Samsung Galaxy S3. Is there any conceivable advantage to the BMW Snap In Adapter, as far as audio integration is concerned?
Thank you!
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 03-12-2014, 02:20 PM
markl53's Avatar
markl53 markl53 is online now
bimmerfest Supporting Member
Mein Auto: 2014 535i
#1 and #3: No
#4 - simply request the dealer to center the steering wheel. There should not be an argument. Don't always prepare for the worst, IMO.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 03-12-2014, 07:02 PM
Carbon Fiver Carbon Fiver is offline
Mein Auto: 2013 535i M-sport
You should definitely notice that when you change the Mode to Sport, the tranny will usually downshift and hold higher revs before upshifting. I can't really tell if the shifts themselves are milliseconds faster, but you'll definitely notice you're in lower gears with more ready power.
Just experiment with the shifter and mode on your drive, changing them up to see what happens.
I will usually see that changing mode to Sport makes a downshift, then if I put the shifter in M/S it'll make another downshift. But not often the reverse. ie in Comfort mode, put shifter in M/S makes a downshift, then change to Sport mode usually won't make another downshift. But Sport mode gets you the faster throttle response which I like.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, Sport Auto, Driver Assistance Pkg, Premium Pkg, Multi-Contour Seats, Heated Seats, Navigation, H/K stereo. Michelin Pilot Super Sport non-runflats, M5 grille, Painted reflectors from IND.
Old 03-12-2014, 07:10 PM
Mein Auto: BMW 535d
I have tried and cannot figure it out.
A shifter move from D to S definitely results in a downshift. A move from Comfort to Sport almost never does, and when it does, I think it's just throttle remapping that causes it. If I'm in D, a change from Comfort to Sport results in no discernible difference.
Robert A
BMWCCA Member
Current
Prior
Old 03-12-2014, 07:14 PM
bmw325 bmw325 is online now
Mein Auto: 528i
Robert-
I recently took delivery of a 528 in Munich at the Welt and asked the delivery specialist the same question. Her answer was an emphatic "NO" (with head shaking) when asked if the DDC switch affects the transmission. That's consistent w/ my experience with the car so far as well, and makes logical sense. Your theory about how the throttle remapping might sometimes cause a downshift when switching to the sport mode also makes a lot of sense.
Old 03-15-2014, 09:40 PM
namelessman namelessman is online now
Mein Auto: bimmer
Mine 8AT(without SAT) does downshift when changed from Comfort to Sport dependent on the rpm. For sure Sport up-shifts at higher rpm than Comfort.
Old 03-15-2014, 09:51 PM
Mein Auto: BMW 535d
But can you be sure the delayed upshifts aren't caused by more aggressive throttle mapping?
Robert A
BMWCCA Member
Current
Prior
Old 03-15-2014, 10:30 PM
Mein Auto: bimmer
My layman understanding is that the drive modes affect throttle mapping while the shifter position controls the transmission shift responses. 6MT surely looks easy doesn't it?
Old 03-15-2014, 10:35 PM
Mein Auto: BMW 535d
Then I'm a little confused by your conclusion. I thought you said previously that shifts points were affected by the mode switch.
Yes, 6MT is much simpler and more direct.
Robert A
BMWCCA Member
Current
Prior
Old 03-15-2014, 11:29 PM
jagu's Avatar
jagu jagu is online now
Mein Auto: 2016 550i
When I put my car in sport mode with the button, I get an almost violent boost but I prefer to just jam the gear lever to the left where the reaction is more smooth and seamless.
2016 BMW 550i/M-Sport/Dynamic Handling/Executive/Lighting/Cold Weather/Driver Assistance/Jet Black-Black Nappa.
Old 03-15-2014, 11:46 PM
Mein Auto: bimmer
It is more an observation than a conclusion. The shift points are noticeably higher while in Sport than in Comfort, and my guess is those are part of the computer mapping per mode. The M/S position itself also affects the shift points, but does not seem to be as aggressive as Sport mode(may need to experiment again to confirm). BTW previous F30 posts did comment that sports auto M/S holds at redline without up-shift and does not downshift at kickdown.
http://www.bimmerfest.com/forums/sho...light=8at+mode
Old 03-15-2014, 11:53 PM
Mein Auto: BMW 535d
Life would be simpler if the gear shift had just two positions -- Drive and Manual. Then the mode switch could control the shift points, and we could just leave it at that.
Robert A
BMWCCA Member
Current
Prior
Old 03-16-2014, 12:03 AM
Mein Auto: bimmer
Initially it was fun playing with the different permutations, but it got old after a while(and there is no last-user mode!). These days my driving is mostly Comfort or Sport in D, and infrequent M/S manual shifts.
Old 03-16-2014, 12:43 AM
Mein Auto: bimmer
OK, some observations(on F30 N26 8AT without SAT) on the short drive back home:
1. at constant 40mph, changing from comfort to sport bumps the rpm from 1.5k to 2k.
2. at constant 40mph, while in sport mode, changing from D to M/S(no manual) bumps the rpm from 2k to 2.8k. Going back and forth between D and M/S causes the rpm to change between 2k and 2.8k
(haven't tried comfort mode D and M/S back and forth, my guess is similar to #2 but lower rpm)
So it looks like comfort to sport is one downshift, and D to M/S is one additional downshift. F10 8AT probably should behave similarly.
Old 03-16-2014, 01:18 AM
Eagle11's Avatar
Eagle11 Eagle11 is offline
Mein Auto: 2013 320i
I think you can call it what you want, but if you place your car into Sport, the transmission will downshift a gear and hold the gears longer then in comfort and Eco-Pro. That is why it is called "Sport" and "Comfort".
2016 328xi GT, Imperial Blue, Oyster Interior, Tech, Premium, DHP, BMS Stage 1, Anti Dazzle high beams and other coded goodies. ED 8-28-2015
2013 320i Jet Black, Venetian Beige Dakota Leather, Premium Package, BMS Stage 1, coded goodies.
Old 03-16-2014, 01:32 AM
Mein Auto: 528i
Well, don't forget that the mode switch controls steering effort, throttle mapping and damping (if so equpped) so there's more to it than transmission shift points (if it even affects those)
Old 03-16-2014, 01:33 AM
Eagle11's Avatar
I wasn't going to confuse the OP more then what they are.
Old 03-16-2014, 01:52 AM
Mein Auto: BMW 535d
Stepping on the gas also causes delayed up shifts. The revised throttle mapping may be doing the same thing.
Robert A
BMWCCA Member
Current
Prior
Old 03-16-2014, 01:54 AM
Mein Auto: BMW 535d
It doesn't confuse me. I understand these factors as well.
Robert A
BMWCCA Member
Current
Prior
Old 03-16-2014, 01:57 AM
Mein Auto: bimmer
One observation is, if shifter is in M/S position(left), switching among /Eco/Comfort/Sport does not change the shift points, e.g. at 40mph, all modes are at, say, 2.2krpm, provided it is constant cruising at 40mph. However, if the engine is under load(e.g. slightly accelerating and/or uphill), switching from comfort to sport(with shifter at M/S mode) would still bump rpm from 2k to 2.8k. Having said that, Comfort to Sport seems to bump up the rpm in D most of time even when constant cruising.
Old 03-16-2014, 07:43 PM
Art234 Art234 is offline
Mein Auto: 2014 535d x drive
If I recall correctly, putting the transmission in sport mode delays upshifts, but also locks out 8th gear, so if you enter it above 50 mph or so, you will automatically downshift to 7th, hence the rpm jump.
2014 535d xdrive ED 4/28/14 Glacier silver, Ivory Interior-Soft Close Doors, Ash wood, Harmon Kardon, Cold Package, Driver Assistant and Driver Assistant Plus, Luxury Line, Lighting Package, Luxury Seating Package, Premium Package
Old 03-16-2014, 10:37 PM
Mein Auto: BMW 535d
When you put the transmission in Sport mode (and by this I assume you refer to moving the lever to the left), it clearly does this. The question is, how does the Driving Dynamics Control (DDC) affect the transmission? What's the interplay between the DDC and the shift lever?
Robert A
BMWCCA Member
Current
Prior
