Old 03-13-2014, 12:17 PM
Mrlucas Mrlucas is offline
Mein Auto: 2001 740I
Trans cooler temp normal range ?
Anyone know the normal operating temp range of the transmission oil cooler voltage reulator thingy? I have a feeling that my Cooler thermostat is not working or the unit is plugged. Cooler is extremely hot and lower portion of radiator is cool. That makes me think maybe it is not opening.
I will prevail on all these issues I swear
2001 740i Sport
740i m sport 2000/01 - M62TU Vanos V8
Old 03-13-2014, 01:19 PM
Splitdog Splitdog is offline
Mein Auto: 2001 740iL
I had tranny issues. Mine had 160,000 on her and it would drop and stay in a lower gear. The trans was overheating. We opened her up to check the temp sensor and ended up just rebuilding her. Afterwards it drove great but still dropped a gear automatically. I dropped the cooler and the water side was completely clogged. With an aluminum-like sludge. I just bought a new one and installed it right away. Problem solved. Check those coolers!!!!
Old 03-13-2014, 05:02 PM
Heres to hoping that is plugged and not something worse. Shift great until that sucker gets hot as hell. Have not really been able to drive it as a result. Will pull it off tomorrow and see if it is clear. If not will clear it/ replace it then do a fluid drain filter and fill. After I get my handy dandy dipstick.
HTML code is Off
