Old 03-13-2014, 03:07 PM
Shakeydeal's Avatar
Shakeydeal Shakeydeal is offline
This space for rent
Mein Auto: 2007 335i coupe
Trunk spoiler didn't stick......
As the thread says........
I put my new spoiler on tuesday. I prepped the trunk by cleaning with isopropyl alcohol. I applied the 3M tape supplied with the spoiler and it seemed to hold pretty well. Today it was loose, so I removed it. The tape adhered well to the spoiler, but not so much to the trunk.
The only thing I can think of is that it rained yesterday, but I didn't drive the car. I drove it today.
Any thoughts on how to proceed with round two?
Thanks,
Shakey
Don't worry about avoiding temptation. As you get older, it will avoid you. - Winston Churchill
Old 03-13-2014, 03:14 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Use some paint cleaner on the painted surface, there may have been some sealant or wax left on the paint. Alcohol will not remove waxes or sealants.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 03-13-2014, 03:29 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Thanks,
Shakey
Did you do this:
Once all the backing is peeled form under the part, apply some really firm pressure for about 30 seconds in all mounting places. The 3M tape needs to bond with the mounting surface, and it needs pressure to do this. The part will seem like it is stuck on, but keep pressing for at least 30 seconds.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 03-13-2014, 03:36 PM
Shakeydeal's Avatar
This space for rent
Two really good tips, thanks!
So Goo Gone is good to clean the trunk with?
Shakey
Old 03-13-2014, 03:48 PM
wilt wilt is offline
Mein Auto: 2011 328i
Shakey
Oh gawd, no, you leave a film of Goo Gone and nothing sticks!
I don't know what the body shops do to clean the surface, before they stick these things (which is how I added a rear spoiler on the E46 right after my car arrived from Germany, since it had to be painted to match the car).
But maybe using polishing compound on the narrow area where the spoiler will stick would clean off wax without leaving a oily film that has to be then cleaned off.
Old 03-13-2014, 03:50 PM
Shakeydeal's Avatar
This space for rent
Yeah, that makes sense. Now that I think about it, GG is not a good idea.
Shakey
Old 03-14-2014, 04:46 AM
Mein Auto: '06 AW 330xi
If its cold where you are, the adhesive is less tacky.
Heat it up before and after applying. Also keep it dry for a couple days...check the forecast
Old 03-14-2014, 05:12 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Thanks,
Shakey
What you need is a grippy surface!
Try Goo Gone instead of rubbing alcohol.
Then, a light sand blast - she'll stick now!
Old 03-14-2014, 08:07 AM
The Goo Gone is so the sand won't stick to the paint, right?
Old 03-14-2014, 12:25 PM
Mick the Quick Mick the Quick is offline
Mein Auto: 2011 335i xDrive Sedan
Use a heat gun on the 3M tape.
Mick
