Old 03-14-2014, 07:27 AM
bimmerbeauty bimmerbeauty is offline
Mein Auto: 2014 435 M Sport
07' 328 Question
Hi everyone, I am new to the forum.
I have an 07 328XI that i absolutely love. Only thing is she is nearing the 140km mark.
Now I drive quite a lot, 30-40k a year, my question is,
how reliable will she be as the KM keep adding up?
Thank you!
Old 03-14-2014, 10:08 AM
nobody?
Old 03-14-2014, 10:20 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Thank you!
My question is, which scale or gauge should we use? Is there a Canadian or metric measure? What is our origin of reference?
Or do you look for "Very" or "not so much" or "average," in which case, how would you know what we mean?
Old 03-14-2014, 11:13 AM
.................... I just wanted to know how reliable 3 series usually are after 140,000 km
Old 03-14-2014, 01:40 PM
bracer028 bracer028 is offline
Mein Auto: 2007 328i
It is not reliable.
Your engine is probably the only thing that will last.
Old 03-14-2014, 01:45 PM
wilt wilt is offline
Mein Auto: 2011 328i
Compared to the two British sports cars with <100k which I had, a BMW with >100k is very reliable and troublefree
Old 03-14-2014, 01:52 PM
Thank you!
Old 03-14-2014, 04:40 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Originally Posted by bracer028 View Post
It is not reliable.
Does anyone else see the irony of this post?
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 04-03-2014, 10:34 AM
Roadawg Roadawg is offline
hi mileage user
Mein Auto: 91 318is, 97 Z3, 07 328i
Cool Preventive maintenance and common sense goes a long way.
I drive a 2007 328i and I intend to make it last for a long time. A lot less $ than a new one, and I prefer the old technology.
Remove the valve cover and replace the gasket and the three seals, replace the spark plugs and coils. Flush the cooling system, and change out the oil and filters in the engine and transmission, and the oil in the rear end. Ask a tech to check your belts. Lose the hard hitting run flats, and replace with Nokian all season go flats. Put a water pump and a thermostat kit in the trunk along with a jack, a spare wheel and tire, gloves, a hi vis vest, warning triangles, a first aid kit and a few tools.
Use good quality fuel, I like Chevron 94 with techron and no ethanol, and have never had injector issues. Change out the engine oil and filter every 10k or so.
Treat your car right and it will run for a long time.
Old 04-03-2014, 10:48 AM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
You're planning a field water pump replacement? What is the point of buying a modern car if you have to carry around a trunk full of tools and replacement parts.
Old 04-03-2014, 10:49 AM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
It is not reliable.
Strongly disagree.
And one thing you can count on is that maintaining a car through 200K miles or so is less expensive than paying for a new one. You may reach a point where a specific expense exceeds the value of the car, but that will be years and miles in the future.
With any car, preventive maintenance is less expensive than corrective maintenance. Stay in front with oil, filters, lubes, fluid changes and alignments.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 04-03-2014, 12:49 PM
hi mileage user
Thumbs up '07
The OP asked about an '07 328i. Bimmers are not trouble free but you can make them last forever if you work at it.
My '91 318is has run over half a million k and continues to run just fine albeit with a well used S52 engine. My '97 Z3 has 170 k on the clock and runs like new, and my '07 328i has 117 k on the clock and likely runs better than when it was new.
If you can afford a new car, and write it off, and are never far from a dealer, then a new one works for sure.
But I am often way off in the boonies with my dog, Gator, and prefer to rely on myself. And I prefer the older technology, and if I can make a new one run as well as a new one, then why pay extra to take a lot of depreciation?
But the water pumps are a wild card with the '07 328's. At 140k it makes sense to swap it out in advance.
Just saying that if you do what needs to be done, it will run, and run, and run some more.
Old 04-03-2014, 01:04 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
nobody?
Did you try searching here? This topic comes up more than once per week.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
