Old 03-14-2014, 01:56 PM
endlessbummer endlessbummer is offline
Mein Auto: 2008 E90 6-speed
Side view mirrors not going back to position
Anyone else have the problem after where the passenger side mirror does not return to the proper position after going into reverse? It is intermittent. I can manually reposition the mirror, so they do not appear to be stuck, but annoying none the less.
Old 03-14-2014, 02:19 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Time honored way to access the massive resource of Forum experiences: Set your Google to E90 Side view mirrors not going back to position
Viola and Violins! It'll make your day....
Old 03-14-2014, 03:14 PM
Not familiar with this dark magic 'Google' thing you refer to. I did go onto the interwebs and with a Altavista seachie thing was able to find a good write up on the process of cleaning the contacts and applying contact grease.
For those who don't know where to set your google, VCR related perhaps?!?! Here is a good write up for you.
http://www.e90post.com/forums/showthread.php?t=683764
Old 09-15-2014, 01:37 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
This works. I did it a week ago and my mirror always returns to the set position. Great post. Before it always moved but not to the correct spot.
Old 12-10-2016, 02:34 PM
jongould jongould is offline
Mein Auto: 328xi
My passenger-side mirror has started to rotate too far after the mirrors have been retracted and then extended to their normal position. My quick fix for this is to place both mirrors in the retracted position and then manually rotate the passenger-side mirror to the overly extended position. Then press the button to extend the mirrors. The passenger-side mirror will "click" because it has nowhere to go. It will then return to the correct extended position.
