Old 03-14-2014, 02:19 PM
sle39lvr sle39lvr is offline
Mein Auto: 08 E90
Cylinder 2 Misfire
Today, all the sudden I got rough idle and got "Service Soon" light. When I scanned, I got this:
I am guessing Coilpack?
Since I have BT Tool, what can I do diagnose this further?
Old 03-14-2014, 02:21 PM
Mein Auto: '06 AW 330xi
Or spark plug or injector
First swap coil pack to a different cylinder...does the code follow?
Yes? Then replace the coil pack.
No? Then move the spark plug to a different cylinder....does the code follow?
Follow the same procedure as above.
For injectors, you need to replace the seal/retaining clip every time you pull them out. So make sure you have them ready.
You don't need to code the injectors to test the function. Only if you install a new one. But move them back to the original cylinders after testing.
Old 03-14-2014, 02:54 PM
White94RX White94RX is offline
Mein Auto: E39 540
335 or 328?
335, I can guarantee its an injector.
328, I can guarantee you its a coil.
BMW Level 1 Master Certified
2001 BMW 540i
Old 03-14-2014, 05:28 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Hoooooold on buckaroos. Take a look at the freeze frame (should be tons more data, but we'll use that). Cold engine. Accelerating. High load. The CEL did not flash at any point and the fault is "not currently present".
I'm calling glitch. OP, relax, you're probably OK for now. At almost 100K though you can look forward to some new parts in the foreseeable future.
Old 03-14-2014, 05:51 PM
Mein Auto: 08 E90
Originally Posted by White94RX View Post
335 or 328?
328i.
@DSXMachina:
I ran this while the ignition was on, not running.
What more data can I present, to diagnose this better?
Old 03-14-2014, 06:49 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Gotta replicate - need statistical certainty! Happen again?
Old 03-14-2014, 06:50 PM
Mein Auto: 08 E90
Originally Posted by CALWATERBOY View Post
Replication. Gotta replicate. Happen again?
YEP.
I cleared it, drove again..same rough idle...same light..same code..
Old 03-14-2014, 07:32 PM
YEP.
Same cyl? Swap coils....
Old 03-14-2014, 07:43 PM
Mein Auto: 08 E90
Same cyl.
I have CPO warranty. $50 deductive... Wonder if its worth to take it in rather than putting one in my self..
Old 03-15-2014, 02:56 AM
Banned
Mein Auto: 2007-335 HTC
Same cyl.
thats what the warranty is for, you cant do it your self for 50 but its just the time sitting at the BMW place that is annoying
Old 03-15-2014, 06:00 AM
DSXMachina's Avatar
Bimmerdex 7.4!
328i.
@DSXMachina:
"Freeze frame" data is recorded when a code is set. It records all the PIDs at the time of the code. The information is extremely useful in diagnosing a problem. With the additional info you posted about the recurring code and misfire I agree with others that you should check the coils.
As was suggested, swap coil 2 with any other coil and see if the problem follows the coil. At the same time move the sparkplug to a different cylinder (but not the same one you move the coil to). Drive the car. See which cylinder is misfiring now.
Old 03-15-2014, 07:24 AM
Same cyl.
And that's the dammable hell of it.....do you want to be without your ride for at least a day?
I say just switch coils; observe. Then:
  • You'll know
  • You'll still be driving your baby
  • You'll be more familiar with you car
Then when you take it in, it's a quick fix.
Know your ride! Benefits are many!
Old 03-15-2014, 07:25 AM
Mein Auto: 08 E90
True
Old 03-15-2014, 10:32 AM
Mein Auto: 08 E90
Took it to dealer just to see what they say...
It was just a coil pack...replaced and I was out of there $50 + tax.
I do think I should keep a spare coil pack just in case.
Thanks for those who helped!
Old 03-15-2014, 07:24 PM
TrickyNick TrickyNick is offline
Mein Auto: 2006 E90 330i ZSP ZPP ZCW
I had the same symptoms with mine @ 90k miles and ended up replacing all the spark plugs and coils myself. The plugs first ($20 each)...then the coils 3 at a time ($80 each).
I think it's best to replace all of the coils at once because if one of them is gone, like wheel bearings, another will be soon to follow. The work wasn't difficult except for the cold weather...but I wish I had a warranty.Click image for larger version
06 330i Sport/Premium/Winter/AlpineWhite
Old 03-16-2014, 08:26 AM
SKWDMD SKWDMD is offline
Mein Auto: 2006 325i
2006 325i, purchased 7/2005, with 45K miles.
Replaced the first coil 2/11, and the second 9/12. No others since then. I believe I read on one of the forums that position and heat issues have a lot to do with failure. The first to go was the #1, and the second was the #2.
Old 03-16-2014, 10:08 AM
DSXMachina's Avatar
Bimmerdex 7.4!
The $50 was you deductible on the warranty? Don't want to mislead those who are off the warranty.
Post 3, White94RX nailed it.
Old 03-16-2014, 10:41 AM
Mein Auto: E39 540
Yeah... I've been doing this for awhile. Lol.
2001 BMW 540i
