My 2009 E91 328i wagon has always had a large amount of sunroof wind noise coming from directly over the driver's head since I purchased it 2 years ago. I took it to the dealer to get resolved w/ some other minor issues and they 'forgot' to fix the sunroof problem. Happens that I crossed 50k miles a month later and the CPO warranty doesn't cover seals.
So, I finally got tired of driving w/ the sunroof shade closed and started googling; I came across several posts about about replacing the sunroof perimeter seal for only $30. Time to take the plunge!
The entire job took about 2 hours. The only tool needed was a Torx T25 driver. You'll also need paint prep/ goo gone/ or some degreaser to clean the metal surface before putting the new seal on.
Note: I did this without a Bentley manual or much other guidance. I just went to town! So, your mileage may vary...
1- Start with the sunroof in the 'vent' postition
2- There were suggestions that you could remove and replace the seal without removing the sunroof glass. Per the pictures, there just wasn't any room between the glass and edges to get at the seal out cleanly, so I removed the glass.
3- remove the 'accordian' cover from both sides of the front glass. It's held on by u-channels on top and bottom. Just start at one end and slowly work it off the rails.
