Old 03-18-2014, 03:14 PM
Liamket Liamket is offline
Mein Auto: 2006 Z4 3.0si
Z4 3.0si Alignment off? pulling all over the road
i have an '06 3.0si with about 115,xxx miles on it. Recently it has been pulling me all over the road. It's not as though it always pulls left and the alignment is off. But rather, if everything is perfectly flat it will drive straight and true. If there is a bump or a grade, or I am switching lanes, it suddenly pulls hard that direction. i would say it's to the point now where the top center of the steering wheel is at either 11 or 1 when it's pulling. This is making it hard to drive, especially on windy roads, because i never know what to expect.
the front tires are somewhat cupped on the inside edge, though i find it hard to believe that tires alone could do this. Also, I had an alignment done 6 months ago.
There has always been a hint of this problem since I bought the car, but only in the last 1,000 miles has it become something serious enough to worry me.
Any thoughts?
Old 03-18-2014, 03:49 PM
LarkHouston's Avatar
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2013 Porsche Boxster S
What is the build date? Pre July 2006 builds have a known steering issue. Google "Z4 sticky steering"
BMW split the cost with me to replace the steering on my June 2006 build Z4 about 2 years ago. But I only had 45K or so miles at the time.
2015 Audi SQ5
Recent Past:
2009 335i Coupe Dinan S3
2006 BMW Z4
Old 03-18-2014, 03:51 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
If you have excessive toe out you can get what they call "tramlining" where the car will try to follow grooves, creases, road stripes, etc. As the tires wear and get some cupping it amplifies the effect. For auto cross or track we usually adjust to zero toe to get a better turn in response, but the side effect is noticeable tramlining during street driving. When you go back to get another alignment, make certain they actually adjust to the nominal specs, not just check to see if it's in tolerance.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 03-18-2014, 04:22 PM
kalali kalali is offline
Mein Auto: 2003 Z4 2.5
Sorry but totally irrelevant to the symptoms described. Sounds like you need new front tires. You also need to find out why the tires are cupped.
Old 03-18-2014, 05:11 PM
Pierce Pierce is offline
Mein Auto: 89 325ix
Do you have run flat tires on the car?
Old 03-18-2014, 09:23 PM
I believe it is a Feb build.
Yes I do have run flats.
As to why they are cupping, I know the camber is a little negative.
I've also noticed, especially when cold, that turning the wheel all the way to the right and backing up (as in backing out of a parking space) causes the front suspension to feel as though it is binding. Maybe this is a part of it?
Old 03-19-2014, 07:14 AM
SC2003Z4 SC2003Z4 is offline
Mein Auto: '03 Z4 2.5i Silver/Black
Get rid of the run flats. You'll be wishing you did it the day you bought the car.
Javier 03 E85 2.5i
Old 03-19-2014, 07:44 AM
coolvt coolvt is offline
Mein Auto: 2007 Z4 3.0si
The run flat tires could contribute to handling problems, but before making changes I suggest that you verify that you have a perfect allignment and that you have a front end (steering snd suspension) that has no wear. Loose and/or worn parts like wheel bearings, tie rods, shocks, bushings, etc. can all contribute to bad handling. In other words you have to get the car back to nearly new specs before you begin making changes. The factory would not have let cars out the door that ran all over the road because of run flat tires.
Old 03-19-2014, 12:02 PM
keeton keeton is offline
Mein Auto: '07 3.0si
+1
When I have had cars that started to wander or shift direction on its own is was usually a worn suspension part (bushings in particular) that would allow the suspension components to shift, thereby changing the geometry of the steering system while you were driving it.
Old 03-19-2014, 04:16 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
"Cupping' is not caused by negative camber. The camber is always negative on a street or road track car...
Cupping is normally caused by worn dampers (shocks), bushings, tie-rod ends and/or an unbalanced wheel.
My car is set up with -3.0' of front camber and -2.0 of rear camber, and it is a daily driver (when it is not raining) and I have never experienced any cupping.
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 03-19-2014, 07:46 PM
Mein Auto: 89 325ix
By all means check the alignment. But having wrestled my 07 Si from Phoenix to Seattle with run flats and nearly changing lanes into another car, I got rid of those things and reduced my tramlining by 50%. I put Conti DW's on it. It's still twitchy, but not near as bad. I consider it the nature of the Si sport option beast!! That car just is not going to drive as nice as my 330Xi. Even with H&R springs and Koni shocks.(on the 330xi)
Old 03-20-2014, 07:24 AM
Guess that's a question that hasn't been addressed........are most of the handling complaints on cars with the "sports" option?
Old 03-21-2014, 07:09 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
My 04 3.0i ran all over the road when I had run flats and truck ruts to fall into, once I got rid of the run flats that was cut down considerably. I have never had a handling issue with my M.
Regards
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
3.0si, alignment, chassis, steering, z4
