Old 03-19-2014, 07:51 AM
funkle funkle is offline
Bimmerless
Mein Auto: Z4 M Coupe
M Coupe tires for street/autocross
When I auto crossed my new Z4M, I felt like the Michelin PSS tires were not very grippy. This could be because they're nearing the end of their life, or maybe they simply aren't as grippy as the latest street ax tires. I'm wondering if one of the go to autocross street tires might make a better choice. I love the Bridgestone RE-11 on my Mini. Thinking of this or the Dunlop ZII. I know these tires are all over the cars you see at AX events on the Miatas and STIs, but not sure if they're a good choice for something like the Z4M
Any thoughts?
Old 03-19-2014, 08:23 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
I'm running the Dunlop ZIIs for auto cross and I'm very pleased with them. I'm seeing a lot of people switch to them too. The BF Goodrich G-Force Rivals were supposed to be the new "must have" tire but some the people I know that have switched to them haven't had a lot of positives to say. This might be a bit of a red herring though, because some of them are switching from R-comps due to the SCCA rule changes.
I was running Hankook RS3s on my E36 and I was happy with them. Only negative is they need some heat before they really grip.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 03-19-2014, 11:03 PM
Bimmerless
Thanks for the reply. Do you daily drive them? I spoke with Alex at TireRack, and he confirmed that the PSS are going to be a lot less grippy than the RE11s, but will wear longer. It turns out the only option for my 19" wheels are the RE11s. No complaints there.
Old 03-20-2014, 10:16 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
I have Michelin PSS's and find them grippy enough for sport driving, but I would not go that an expensive a tire for track, I like the Cont. DW's, very good grip and much more reasonably priced.
Regards
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 03-22-2014, 12:24 PM
Bimmerless
Regards
I do like driving the same tires for AX & street, because the skills you learn racing transfer directly to street driving. Not that I'm driving at AX speeds on the street, but I like to know how the car is going to behave in an emergency evasion maneuver. You could be in trouble if your reflexes were based on a different tire in an at the limit situation.
After spending more time with the PSS's, I've gotta say they are downright greasy. So easy to break loose even with mild throttle out of corners, it's making me a bit nervous. I wonder if they've just seen too many heat cycles and have lost their oomph. The rears are pretty worn on the inside. Fronts still have a lot of tread depth. I'm pretty close just putting RE11's on. They are a lot less expensive than the PSS's and offer an amazing amount of grip - nearly impossible to break loose in my Mini at sane street speeds - there are a few sweeping on-ramps where I'm able to gradually approach the limits of traction. RE11 let go in a predictable, gradual way with good audio feedback, verses the PSS's which seem let go immediately with no warning. I realize this is considered the benchmark for this sort of tire, but man, I'm just not feeling the love - M Coupe feels so planted & balanced in the corners, but these tires are just not doing it justice.
