E46 (1999 - 2006)
Old 03-19-2014, 09:59 AM
tgill tgill is offline
Mein Auto: 2001 330i
001 bmw 330i idle problems
2001 bmw 330i idleing problems low idle,i have replaced spark plugs ,fuel pump and filter, new disa valve cleaned idle control valve and new mass air flow,air intake boot is in good shape....what else is it idles at 600rpm when cold as it warms up idle is al over thr place surges and then stalls please help
Old 03-19-2014, 07:00 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Check your 02 sensors real time data. A bad one can easily cause idle issues.
Old 03-19-2014, 07:59 PM
samster1 samster1 is offline
Mein Auto: 2002 bmw 320i
Originally Posted by tgill View Post
2001 bmw 330i idleing problems low idle,i have replaced spark plugs ,fuel pump and filter, new disa valve cleaned idle control valve and new mass air flow,air intake boot is in good shape....what else is it idles at 600rpm when cold as it warms up it goes from 500-1000 rpm surges and then stalls please help
Check your anti-freeze level, check iy cold before you start the engine, at cold the stick in the expansion tank should be up in the air, starting an engine cold and idles at 600 rpm is not right, cold it should idle at around a 1000rpm and tapper down to about 600 when warm, so the engine thinks it's hot at cold start, so it's not getting enough fuel, so thats why it cycles......so if the antifreeze level is ok, check with a monitor to see what the coolant temp sensor is at cold before starting the engine or use the options in the dash to see what the temp is at with key on.......
Old 03-19-2014, 09:08 PM
crackerlee crackerlee is offline
Mein Auto: 2003 325Ci Convertible
Put a can of seafoam ($10) in the tank and fill it up with gas.
Old 03-20-2014, 08:19 AM
marcozandrini marcozandrini is offline
Mein Auto:
Have the codes read first. I bet you'll see a P0174 code. Replace upper and lower air hoses.
Old 03-20-2014, 08:48 AM
smolck's Avatar
ROLL TIDE!
He said they were in good shape.
Old 03-21-2014, 08:30 AM
Mein Auto:
Visually in good shape. I bet at that mileage they leak.
OP, pull the codes before you go any further.
