Old 03-19-2014, 01:53 PM
mickibarry mickibarry is offline
mickibarry
Mein Auto: 2005 Z4
Soft top
The button to open and close my soft top just stopped working...had just used it and when I got back in my car to open it wouldn't work. Anyone have this happen? I don't think it's the motor because it never made any unusual noise when opening. Do you think it is electrical? Any help would be appreciated.
Old 03-19-2014, 03:29 PM
fastgaas fastgaas is offline
Mein Auto: 2004 Z4
The most obvious thing is the disable switch has been activated by moving the shelf in the trunk. If the shelf is moved up (large boxes in the trunk perhaps?) the the top automatically disables the top lowering so you don't "crush" the pocket with the top. Sometime the switch just goes bad or the shelf goes out of alignment. I would move the shelf up and down and see if it's locking into the center slot.
Other than that there are a series of safety items that prevent the top from going. Make sure things are secure. You can manually open the top by enguaging the release in the trunk and lifting or closing.... might be good to get things going.
Typically when the top releases to open, but does not move and red light flashes means the motor is dead.
Try searching the you will find lots more information.
-H
Old 03-19-2014, 03:31 PM
mickibarry
Mein Auto: 2005 Z4
Thank you! I will try all of your suggestions...much appreciated.
