Old 03-20-2014, 09:55 AM
resunoiz resunoiz is offline
Mein Auto: 520i E60
"trick" for handbrake with some teeth gone...
the last 3 teeth of my handbrake are gone, and so it doesn't grips on higher positions except the last one
it can be fixed at 6th ,7th teeth and at that position does not block the car (common problem with all bmw's..) on sloping streets.
I noticed a little "trick": with the car shut off, if you engage the handbrake and then push the "pedal brake", release the handbrake, release and push the pedal, then again pull the handbrake, it stops tightly the car, and the lever has way less escursion: seems it can lock the car.
do you ever noticed it?
except from tightening the handbrake with the hole on the wheels, E60 does not have the two bolts under the lever like e46, e36 and so on?
Old 03-22-2014, 08:31 AM
Mein Auto: 520i E60
in addiction: for those who have an almost efficient handbrake, how many teeths do you nedd to "lock" the car in place, for example in planar streets ,engaging the clutch and trying to move?
Old 03-22-2014, 09:29 AM
aber57 aber57 is offline
Mein Auto: 2007 550i 6MT
A spring is used on the handle end of cables on E60. In order to get a really hard apply of brakes you have to pull 7-8 clicks. My car will hold on a steep hill with 4 clicks but the feel of the handbrake is too light and it does not give you confidence that it will hold. The models without the spring give the high effort at 5 clicks. These are with the park brake adjustment performed with the star wheel through lug bolt hole.
