Old 03-20-2014, 10:16 AM
gpool75 gpool75 is offline
Mein Auto: 2006 325i
cylinder 5 misfire. please help
I got a cylinder 5 misfire code, idle has been rough. i changed all 6 spark plugs, and the idle got more rough and service engine light is still on. what should i try next? any ideas
Old 03-20-2014, 11:17 AM
Mein Auto: '06 AW 330xi
Change the coil pack on the misfiring cylinder.
Your plugs are most likely incorrectly gapped.
Even if the manufacturer claims they are pre-gapped, I've seen on multiple occasions, the gap is incorrect.
Resetting adaptations will also help.
Old 03-20-2014, 11:41 AM
DSXMachina's Avatar
Bimmerdex 7.4!
What is your current code(s)? This would go a long way toward diagnosing the problem.
Old 03-20-2014, 12:05 PM
P0305 was the code. I will change the coil pack. i'm guessing i gotta pay at least $60 for one
Old 03-20-2014, 12:12 PM
I should rephrase what I said.
I meant to say swap the coil pack on cylinder 5.
Take a coil pack from say, cyl 4 and swap it with cyl 5.
If the code follows, it's the coil pack that is bad.
Injectors rarely fail on the N51/2
Old 03-20-2014, 12:52 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Read with....what? It is way too common that Autozone reads the codes, or Pep Boys, or some other clueless entity.
Do not go there my son. Link above will show you the way.
