Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 03-22-2014, 06:18 PM
jdarnold1990 jdarnold1990 is offline
Mein Auto: 1984 bmw 633csi,
Angry 1984 bmw 633csi NOT CHARGING
I cant Figure it out new alternator good battery the battery light comes on and in the store the alt. puts out 13.9 volts but in the car it only puts out 2 volts im at a loss here i checked all my grounds and there good im trying to see if there is a common problem that can cause it to not charge a place to look. it all started when the ignition went out. i replaced it though.
Old 04-14-2014, 10:13 AM
Rouge_cm Rouge_cm is offline
Mein Auto: 1987 bmw 635CSi
Check all your battery and alt. cables and also your ignition cables to and from the ignition coilone might be worn in side the insulation.
Old 05-11-2014, 01:14 AM
i took my whole wiring harness out fixed a blue wire coming off of the diagnostic connector it was barely holding together. put it all back in and now it wont start its not getting spark
1984, 1984 classic, charging system, ignition
