Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 F15 (2014 - Current)
The all new F15 BMW X5 started production August 2013 as a 2014 model year. The new X5 arrives in sDrive35i (RWD), xDrive35i, xDrive50i and a diesel xDrive 35d.
Old 03-22-2014, 11:20 PM
Spottyb Spottyb is offline
Mein Auto: X5 x-drive 30d
Question HUD settings not saving between drivers
Wondering if anyone else has an issue with the HUD display settings not saving in the key profile between drivers.
Ours randomly changes the height setting back to mid when hubby and I switch as drivers. We both like it high as we are tall and sit lower in the seats. We set it around 75-80% and the setting saves until the other person unlocks the car. Then it reverts back to 50%. Have tried saving it in profiles with no luck. All other settings seem fine IE steering wheel height, mirrors etc. and revert to our personal preferences.
2014 X5 drive 30d. Sapphire Black, Anthracite, fine wood, black 20" star alloys, panoramic sunroof, HUD, DAP, PA, lane change, PDC, sports package, sun blinds,
Old 03-23-2014, 08:11 AM
Winfield Winfield is offline
Mein Auto: 2014 X5 35d (F15)
More generally than just the HUD recalling properly, am having trouble just getting the driver 1 and 2 preset memory to recall for each respective driver. I set my settings as driver 2, using my key in the car only, then hold down the "M" button until it is illuminated red while also holding down my "2" button until the red light on the "M" button goes off. But the seats, mirrors, steering wheel level all do not "recall" if I change settings around and then push my "2" button again. Same challenge for my wife with the "1" button and her settings. Any advice? Tried holding "M" down to get it illuminated read FIRST, THEN holding down "2" to set up my memory settings - no luck. Any tips? Thanks in advance.
Old 03-25-2014, 08:52 PM
onefish2 onefish2 is offline
Mein Auto: 2009 MINI Cooper JCW
I am having problems with the HUD height being remembered between drivers as well. I have it set to 3 bars and it always goes back to the middle when I switch with my wife.
Old 03-26-2014, 05:11 AM
TMac99 TMac99 is offline
Mein Auto: 2014 X5 xDrive 35d
Sounds like you are doing it right, other than when you say "hold down". To store the settings, I simply press the M button and release (don't hold). This makes the red light come on. Then I press and release a number button and the settings are now stored. Recalling the settings has 2 different modes. (Note I have comfort access so I don't know if that makes a difference). Immediately after opening the door and before sitting down and turning the car on, a single press of the numbered button will cause the seat to move to the correct position. If you do this after the ignition is switched on, then you have to press and hold the numbered button until the seat has finished all movement.
Hope this helps and yours works ok.
Old 03-30-2014, 09:30 AM
JackJack1 JackJack1 is offline
Mein Auto: 2014 X5 35i
I'm having the same issue between two drivers. The HUD seems to save for me but my wife's setting gets lost when she drives.
Old 03-31-2014, 08:16 AM
ld757 ld757 is offline
Mein Auto: 2014 750ix
same for me.
I guess I would have to take it to the dealer...
Old 04-01-2014, 09:17 PM
Boss_John Boss_John is offline
Mein Auto: BMW 550i 2012
Are you guys both using different keys? Each key has specific settings programmed into them.
Oops read your thread wrong. I have no idea sorry, ask dealership next time
You're in. Probably just a small software bug. Hope you figure it out soon!
Btw check idrive for options?
Old 05-11-2014, 05:57 AM
MotoWPK MotoWPK is offline
Mein Auto: '13 128i vert, '14 X5 35d
We're experiencing this issue with our X5 also - HUD does not remember the height setting, instead returning to mid-height rather than the last set.
Has anyone resolved this issue and, if so, how?
Old 05-18-2014, 07:41 PM
bdaj bdaj is offline
Mein Auto: 2011 x3 and 2011 335d
Same thing here.. Everything sticks but HUD settings
Built to order and picked up 7 days ago. So the issue has not been fixed yet. Other than that we are loving the vehicle.
Old 05-19-2014, 08:33 AM
buckeyewalt buckeyewalt is offline
Mein Auto: X5 50i
Count me in also as to having the problem. I contacted BMW and they said that they have not had any issues (of course) regarding this. I told them that was not the only one as there are plenty more of us out there. They will look into this. They did mention that it could need a system reboot (?). Not too thrilled about this.....
Old 05-27-2014, 12:02 PM
Dmanx5d Dmanx5d is offline
Mein Auto: 14 X5d & 15 X6M
Same issue. only one profile is set in the car and used. Seems to reset itself to lower height setting after random times.
Old 05-27-2014, 04:43 PM
Mein Auto: X5 50i
Try just pushing the seat number profile that you have after you set your profile on the HUD. I works for me and a few others on here.
Old 12-15-2014, 09:20 PM
rayxi rayxi is offline
Mein Auto: 2001 330xi
I have the same problem. HUD height setting stays as long as we don't switch drivers (keys). Once we switch drivers (keys) it goes back to default. All other profile settings are remembered for each key.
I tried setting the seat memory button after adjusting the HUD height but it made no difference.
Old 12-16-2014, 12:01 PM
Tommyvee Tommyvee is offline
Mein Auto: 35i X5
I had that problem. My car needed to be reprogrammed, that fixed it. I believe there were a stretch of MY14 cars produced that were not programmed correctly. I took delivery in early June. I believe there also was a service bulletin (TSB) out about this, I don't have the TSB # unfortunately. I did mentioned the TSB to the service advisor when I brought the car in.
Old 12-17-2014, 05:25 PM
scbmwfan scbmwfan is offline
Mein Auto: 2006 BMW X5 3.0
I had the same issue. It needed a software upgrade. After that, no issues.
Old 12-30-2014, 07:57 PM
I just returned from the dealer and they reflashed the software. Issue is still there. Can someone provide the TSB number please?
___________________________
2014 X5 xDrive35i M Sport
2001 330xi
2004 X5 4.4i (sold)
Old 12-31-2014, 01:20 PM
I don't recall a TSB (or SIB) for this and none was noted on my service record. It did take two visits to the dealer and, they advised, a few re-programmings for the fix to take effect.
Old 04-23-2017, 11:53 PM
Pek75 Pek75 is offline
Mein Auto: Z4 23is & X5 40e
Hmm,
I'm having the same issue on a newly received X5 40e Hybrid.
So a reprogram looks like the way to go
