Old 03-23-2014, 04:10 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Bug in the Cluster
Literally, I have a gnat inside of my speedometer. I took out the gauge cluster box and I can't see how to get the plastic cover off to get it out. I also do not see how it got in there.
It must have been hiding behind a lip of one of the gauges. Anyone ever do it or have the need to that? It is "bugging" me now!
Old 03-23-2014, 04:15 PM
Banned
Mein Auto: 2007-335 HTC
have you googled it? that would bother me too. some how I managed to get spider webs on the inside of my car, I guess from leaving the top down in the drive way
bug the crap out of me too
Old 03-23-2014, 04:23 PM
sptt144's Avatar
Googled....Yes...All about replacing it which, makes sense. I was able to tear apart my old Mercedes cluster but this one looks sealed.
Old 03-23-2014, 05:05 PM
Mein Auto: '06 AW 330xi
Undo the torx screws.
Cut or peel back the tamper seal.
At the harness connector, there are clips at each corner you need to release.
Then it will pull off
Old 03-23-2014, 05:15 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
You have traveled through an ocean of time - to the dawn of the computer age!
Dude....Grace Hopper....
Old 03-23-2014, 05:27 PM
sptt144's Avatar
Sweet. Thank you! I couldn't tell if I'd break anything...
Sent from my SCH-I405 using BimmerApp mobile app
Old 03-23-2014, 05:58 PM
sptt144's Avatar
Well, that was pretty effortless. Not sure why I couldn't figure that out on my own. Duhhh. Wonder if that was a German gnat in there?
Old 03-23-2014, 08:44 PM
CitizenOfDreams CitizenOfDreams is offline
Mein Auto: 1998 BMW 740i
Did it look like this?
Old 03-23-2014, 08:46 PM
sptt144's Avatar
Yes, the one on the right!
Old 03-24-2014, 05:54 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
I recall one other German "bug" in the dash display thread some years ago. CLEAN UP THE factories, Munich!
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 03-25-2014, 07:25 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
We built a clean room that was on an outside wall for one of the big biotech companies a while back. The manufacturing people were thrilled to have the chance to put windows to the outside within the cleanroom.
The windows needed to be triple glazed and very tightly sealed within the cleanroom space. The contractor chose a double glazed glass pair to fit the interior space, then an outer glass trim panel on the outside face of the building. The project was running on a fast track, so the contractor was working double shifts. The inner window pair was fit first, flush to the interior walls, and smootly mated to the wall. The exterior glazing was put on at night, while the inside lights were on. In July. Glued on and caulked to the building. 2 days later, the bug load on the inner ledges of outside pairs of glass became apparent.
