Old 03-23-2014, 06:58 PM
jamesching jamesching is offline
Mein Auto: bmw 525i 2005 e60 sedan
Fuel injector cleaning??
should i do it? i feel like my cars sluggish at time it has 99 thou on it as well. ive seen at bavarian autosport the ones where u gus pour the cleaner into the gas tank when you empty then go get gas right after is this safe and effective ?
Old 03-24-2014, 09:42 AM
oldman12 oldman12 is offline
Location: JB4 G5 iso; BMS backend; ER fmic; Dr.Euro DPs; RPI
Mein Auto: 535i
Get yourself a can of bg44k if you want to clean them. Only fill the tank half way though. Fuel injectors go bad, they dont clog often, but this stuff will help a bit if they are.
Old 03-24-2014, 09:50 AM
How do I know when half way is
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
Old 03-24-2014, 12:33 PM
H F H F is offline
Mein Auto: 2005 545i
Just switch to Chevron gas ,, and forget about it . Techron is good stuff and it will keep and maintain the injectors clean..
Old 03-24-2014, 12:54 PM
ok
so techron and chevron are both good right
Old 03-24-2014, 12:57 PM
times to use
so i should use it on am empty tank drive a couple miles then fill up again with gas right
Old 03-24-2014, 02:01 PM
vk535i vk535i is offline
Mein Auto: 535i
As I know of, Texaco and Chevron gas station that has techron formula in the gasoline that help to keep the injectors clean. If I have to use different gas (like exxon, valero, or 7-11) then every third gas tank I fill up, then I use one of the injector cleaner (lucas or red line).
2014 550i, Jet Black / Black Dakota Black, Bamboo Anthracite Wood Trim, M-Sport Package, Executive Package, LED Lighting Package, M Aerodynamics Package, HUD, Adaptive LED Headlight, Harman/kardon Surround Sound System. Surround/top View Camera, BMW Apps via SmartPhone, Split fold-down-rear seat ...
Old 03-24-2014, 03:58 PM
I use bp so I should wait til im almost empty fill it up wit cleaner then get gas correct?
Old 03-24-2014, 04:41 PM
maxxym maxxym is offline
Mein Auto: 2010 528i
I used the BavAuto stuff on my e39 a while ago. That's stuff is good.
Old 03-24-2014, 05:09 PM
link
can u post a link and so do i put it in when my tank is empty
Old 03-24-2014, 05:16 PM
Mein Auto: 535i
doesn't matter the tank full or empty then fill up. All you need is 1/2 tank of your gas and a bottle of gas treatment add in that 1/2 tank. Drive until the tank empty then fill the gas up like normal. You can do that every 3K miles or every 3-4 tanks. Doesn't hurt at all. Or using Chevron gas or Texeco gas then you don't have to do anything.
Old 03-24-2014, 05:43 PM
ok
ok bc ive heard do it on am empty tank u sure?? dont wanna **** anything up lol
Old 03-24-2014, 06:55 PM
Mein Auto: 535i
what I did, let drive the car with empty tank to gas station then fill the gas tank with the gas treatment first after that fill the gasoline to half tank so they both can mix well then drive until empty and refill gas as normal.
Old 03-24-2014, 07:04 PM
thanks
thanks bro ima try it nd let u know how it went
Old 03-24-2014, 07:14 PM
eWERK-E60's Avatar
eWERK-E60 eWERK-E60 is offline
Mein Auto: E60 550i Porsche 911SC
Lucas 10020 Fuel Treatment- My family has been using it for years, my 550i seems to love it.
Chevron 65740 Techron Concentrate Plus Fuel System Cleaner also very good.
“Racing is life. Anything before or after is just waiting.”
Steve McQueen
Old 03-24-2014, 08:13 PM
H F H F is offline
IMO ,, great stuff . chevron gas has Techron in it . I pulled my injectors out at 100 000 they were clean as a whistle .. Have never used any additives,, just straight chevron ..
Old 03-25-2014, 08:43 AM
MarkieMarkH MarkieMarkH is offline
Mein Auto: 2004 545i
+1 on the Techron in the bottle. I use one bottle per year. They usually go on sale for about $6 each at auto parts stores. Pour it into the gas tank before you fill up so the gas will mix it well. This stuff is so strong you can smell it in the exhaust.
The best advice I can give though is don't run your tank too low. All that crud and sediment just sits in the bottom. The lower you run the tank, the more your chances of sucking that crud up.
Old 03-25-2014, 08:52 AM
luigi524td luigi524td is online now
Mein Auto: '13 535xDrive; '98 Z3 2.8
Techron in the tank!
I also stock up on Chevron Techron products whenever they go on sale.
Once or twice a year is enough (IMHO) and I find the best time is to add it to a full tank just before taking a nice long highway trip; I also suggest you try to vary your speed from time to time - maybe even a spirited run up (say 40mph - 80 mph) from time to time to allow the chemicals to work!
I've also used Lucas and Redline fuel additives over the years - just stay away from anything that pretends to "increase octane or horsepower"! Snake oil
My opinions are free - you'll get exactly what you pay for!
Current: 2013 535xDrive | 2013 X1 MSport | 1998 Z3 2.8
Past: 2007 530xi | 2001 740i | 1998 740i | 1994 740i | 1986 524TD
"Seek and ye shall find" ... start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 03-25-2014, 11:05 AM
husskepj husskepj is offline
Mein Auto: 5 seris
I suggest Amsoil PI. Very good working additive I run it in all my cars..
http://www.amsoil.com/shop/by-produc...?code=APICN-EA
Old 03-25-2014, 11:28 AM
So dont do it when im completely empty
Old 03-25-2014, 12:34 PM
Mein Auto: 535i
What MarkieMarkH said, do not run your gas tank to complete empty because it has more chance to suck in the dirty stuff at the bottom of the tank.
For the injector cleaner use, you let the gas tank to low then fill the gas treatment bottle in to your gas tank first then fill up youR gas tank to half tank or 3/4 (I did mine at 1/2 tank) so the gas will mix up with the gas treatment well then drive.
if you plan for the long trip ( 3-4 hrs drive), do the same thing but you may fill up full tank of gas and enjoy the drive.
IT'S NOT GONNA F**CK YOUR ENGINE. DON'T WORRY !!!
Old 03-25-2014, 06:31 PM
Mein Auto: 5 seris
amsoil PI states how much gas it recommends for usage...
Old 03-25-2014, 08:25 PM
I just wait until I need gas, pour the Techron in (the small bottle is usually plenty), fill the tank as normal and then drive away. Easy peezy lemon squeezee!
