Service Engine Soon - Bimmerfest - BMW Forums
Old 03-30-2014, 10:09 PM
07whitebmw328i 07whitebmw328i is offline
Mein Auto: 328i
Service Engine Soon
Hi - my second post and already asking for some help.
I drove my car tonight and it feels like it's sputtering/hesitation. I continue to drive the car but it feels like it became 4 cylinder car and start shaking, then the Service Engine Soon light came on. I stopped the car at the side of the road and turn the engine off. Waited a few minutes and tried to start the car again. It started just fine and the SES light did not came back on. It drives fine after wards but now I'm worried.
The car is a 2007 328i with 94k miles. Anyone experience this to their BMWs? Any help or advice? Thanks in advance.
Old 03-31-2014, 03:24 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
As you spend more time here you'll notice....it's happened before, and likely will happen again.
So, what's the problem? Right off the bat, can't say.
Why? Could be many things.
How to diagnose? Car does much of it for you! HERE
Old 03-31-2014, 08:26 PM
sptt144's Avatar
sptt144 sptt144 is online now
Mein Auto: 2009 335i
Were you stepping on it before it happened by any chance? Car will try to protect itself and go into limp mode. But Cal is right, happens a lot. Recently happened to me after not happening for a long time. But nothing after that. All is good.
Old 03-31-2014, 10:25 PM
Mein Auto: 328i
Just a normal drive. I felt it's hesitating so kinda step on the gas but it start shaking and choking. Then the Service Engine Soon came on.
Did you do anything or it just fixes itself? I have a Innova scanner and but it's not getting any error. Maybe I need to invest on what Cal just mentioned. It just to expensive.
Old 03-31-2014, 11:28 PM
sptt144's Avatar
You can try the simple thing of removing, cleaning, and swapping the vanos units. Costs you only time. Other than that, new.plugs next, then coils. A really bad coil could leave it stuck in the limp mode. But vanos are primary culprits to a lot of limp engine issues.
Sent from my SCH-I405 using BimmerApp mobile app
Old 03-31-2014, 11:30 PM
sptt144's Avatar
Btw...Ive got a cheap BT scanner with the Torque app that reads codes pretty good and clears them no problem.
Old 04-01-2014, 04:15 AM
Banned
Mein Auto: 2007-335 HTC
if you follow the recommended BMW 15,000 oil change interval, you could be in trouble, ****ed up VANOS and engine, very bad
Old 04-01-2014, 04:16 AM
Banned
why is g o o k e d up a bad word
Old 04-01-2014, 06:06 AM
Last Sight's Avatar
Last Sight Last Sight is offline
Mein Auto: BLT335xi, e92 6MT
That's not the bad one...it's g o o p e d
BMWCCA #489063
The BLT335xi - '11 BMW 335xi, M-Sport, Convenience, Premium, H/K sound, iDrive
1974 Corvette - blue, 4spd, fully loaded
Previous Rides:
'13 Cadillac ATS - Fired
'09 BMW 328xi - KIA by Bambi, reincarnated in Michigan
'01 Saab 9-3 2.0T
Old 04-01-2014, 08:39 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
The Root Word of the term was a derogatory term for some Asians about 50 years ago. I suspect the system has a problem with it.
I would suspect the VANOS solenoids.
Old 04-01-2014, 09:23 AM
Mein Auto: 328i
sptt - thanks for your input. I will try that this week. Would you mind sharing on where did you get your cheap BT scanner. I might need to invest on that if I decided on keeping this car. Looks like I really miss my Toyota now. LOL
Old 04-01-2014, 09:44 AM
sptt144's Avatar
I either got it off Ebay or Amazon. You're welcome.
Old 04-01-2014, 10:18 AM
Mein Auto: 328i
What are the things needed to clean the VANOS solenoids? Can I soak on a gasoline or break cleaner? Do I need to replace gasket once I removed and cleaned the vanos? Thanks in advance!
Old 04-01-2014, 11:39 AM
sptt144's Avatar
Use MAF cleaner or carb cleaner and compressed air. Don't use gasoline. Your goal is to get any gunk or sludge out of them. Then swap them from the holes they were in.
Old 04-01-2014, 01:58 PM
Mein Auto: 328i
Thank you sir!
Old 04-01-2014, 02:12 PM
Mein Auto: '06 AW 330xi
I didn't know that was an offensive word either haha
Old 04-01-2014, 02:51 PM
LJ35 LJ35 is offline
Mein Auto: 2008 BMW 328i
Mine did the same thing a couple days ago leaving work. It was intermittently cutting out under moderate load around 2500-3500 RPM, and felt like no spark to a cylinder or no gas. Turned it off after the SES light same on, then started it up and it drove fine with the occasional misfire.
Lucky for me, my OBD cable came in a few days earlier! I pulled the codes and it was cylinder 2 misfire. Swapped 1 & 2 coils then drove it until the SES light came on. Codes showed #1 misfire. BINGO. Replace the bad coil and all is well.
I bought mine 3/3/14 with 65K and the PO had the #1 coil replaced back in December. I guess when one goes, you can expect more to go. I ordered 5 more coils and a set of plugs and plan to install them next week. Easy job, too.
Old 04-01-2014, 03:24 PM
MB330's Avatar
MB330 MB330 is offline
Mein Auto: 2006 330i
http://www.bimmerfest.com/forums/sho...d.php?t=754336
I did replaced all 6 coils and spark plugs - car drive as the day I pick up in Munich.
'16 320i Alpine White/Black/AT [ZDA, 494, 205, 459, 403]
Old 04-01-2014, 09:32 PM
Mein Auto: 328i
Thanks everyone! I did have a chance tonight to cleaned the VANOS but did not have a chance to test drive it yet. It looks promising though when I started the car. I will find out tomorrow when I drive it to work. I know I'm approaching the 100K miles maintenance and I want to do the spark plug change. What kind of spark plug would you guys recommend to use for this N52 engine?
Again thanks in advance on all your advice and inputs!
Old 04-01-2014, 10:33 PM
sptt144's Avatar
Just did the BOSCH ones today. Super easy! Got them off eBay in two days for $63.00 and free shipping. Bought my socket for $19.00 from Burger Tuning. Car was definitely in need of some electric spark!
Old 04-01-2014, 11:15 PM
Mein Auto: 328i
sptt - will this works =>
http://www.ebay.com/itm/Bosch-FR7NPP...38e225&vxp=mtr
Old 04-02-2014, 03:17 AM
Banned
some say plugs are plugs, I say if you only replace them every 100K then buy the OEM plugs, their have been posts about people purchasing cheap plugs and having bad brand new plugs and chasing misfiring after replacing them
you can order OEM plugs or go to BMW and get them
Old 04-02-2014, 11:40 AM
MB330's Avatar
I get my from www.getBMWparts.com part# 12122158253
I get my dealer to install and they ask for paper work - make sure I purchase this from BMW dealership parts department not from some BS mom and pop shop.
Part Number Part Description Quantity Core Price Price Total
12137594937 electrical, ignition system, ignition coil 3 Series From 4/06 6 $0.00 $51.77 $310.62
12122158253 electrical, ignition system, spark plug W/O 335D, M3, w/o turbo 6 $0.00 $19.06 $114.36
Sub Total $424.98
Shipping method - Standard Ground - US Shipping $26.95
Handling Fee $2.95
Tax $0.00
Total $454.88
Old 04-03-2014, 10:43 PM
Mein Auto: 328i
just an update... after cleaning the VANOS, I still experienced hesitation/sputtering. So I decided to look at the coils and spark plugs. I was suprised that I have (2) different brand of coils (Bosch and Delphi coils) and the spark plugs are NGK BMW. Is BMW really uses NGK spark plugs? Looks like now I know why I'm experiencing the hesitation/sputtering. I'm ordering Bosch spark plugs and coils.
Old 04-03-2014, 11:00 PM
You should have misfire codes....which cyl's?
