Old 03-31-2014, 08:40 AM
Boodski Boodski is offline
Mein Auto: 1999 Z3
Unhappy 1999 Z3 with broken power passenger seat
My 1999 Z3 convertible has a broken power seat motor; I am unable to access seat bolts to remove the seat to access the motor, etc. Is there a way to manually move the seat forward to access the rear anchor bolts? Or does anyone have a solution or suggestion to access the rear bolts? Most of the suggested repair methods I have found for replacement of the motor is to remove the seat (S%@t!!!)..."I am lacking the ability to get to that point in the repair"...thanks for the help...Boodski
Old 03-31-2014, 09:43 AM
AB1945 AB1945 is offline
Mein Auto: '01 Z3 & '02 325i Wagon
http://realoem.com/bmw/showparts.do?...07&hg=52&fg=10
Check the seat diagram above. The drive shafts from each side of the actuator (part #3) at the front of the seat will move it backward and forward. The shafts (part #4) are a flexible cable which will allow you to flex them and pull the ends from the seat rails. All you have to do now is find something that will fit in the seat rails where the shaft was then turn it and the seat will move backward and forward. You'll have to alternate sides so that one does not get too far forward or behind the other. It'll take a while but it works. Good luck.
Old 03-31-2014, 09:49 AM
Mein Auto: 1999 Z3
Smile
Thanks!!! I will give it a try
Old 03-31-2014, 07:20 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Here's the manual method of moving the seat:
http://www.bimmerfest.com/forums/sho...d.php?t=644673
