Old 03-31-2014, 11:09 PM
rulzahl rulzahl is offline
Mein Auto: 2007 335 CV
help identify this broken piece
Hey so I crawled under the 2007 E93 last Sunday and did an annual inspection. I found this broken rubber mount and took a picture thinking I could easily identify it later. I've gone through all the diagrams on realoem.com and flipped through my Bentley and still cannot identify it.
You can see the front axle right there-- help?
Name:	broken rubber mount2.jpg
Old 04-01-2014, 04:04 AM
Banned
Mein Auto: 2007-335 HTC
so what is your question, besides that it needs to be bolted back?
Old 04-01-2014, 07:56 AM
Its actually some type of rubber shock mount that is broken right in the middle so I can't reconnect it. I need to know what the piece is so I can replace it.
Old 04-01-2014, 08:35 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
It is the mount for the power steering hose. They often get broken while replacing the water pump. Replace it soon or use a zip tie to keep if from flopping around until you get the proper part.
Old 04-01-2014, 10:08 PM
Cool, that sounds right but I still can't find that part on realoem. Check out the attached diagram of the power steering assembly-- can you find the right part on there? #4 is the closest thing but its just a hex bolt.
In the meantime, I'll go ahead and zip tie, thanks for the tip.
Old 04-02-2014, 10:42 AM
I couldn't find it there either on getbmwparts.com or realoem.com
