E30 (1982 - 1993)
Old 04-01-2014, 09:12 AM
beammeupscottie beammeupscottie is offline
Mein Auto: 1989 325iC
Slow Window motor
All the window's work on my 1990 325i 4 door. the back passengers is very slow requiring the push by hand to go back up after going down. Is it possable a switch replacement might work or does the motor need work
Life is like a roll of toilet paper...the closer you get to the end the faster it goes. So drive an E30 everyday
1989 325iC Alpineweiss II manual 5 speed Curent ride
1990 325i Glacier Blue 4 door Auto, 1987 X 2 (Black 325ic convertable & Granite silver 325i coup) Gone but never forgotten
Old 04-01-2014, 01:11 PM
downhiller's Avatar
livin large
the motor is probably going bad or the mechanism is really gunked up. either way door panel needs to come off
Old 04-01-2014, 01:27 PM
thanks downhiller firgures a window switch wouldnt be a simple fix I've never had a door panel off guess its time to learn!
Old 04-01-2014, 03:47 PM
downhiller's Avatar
livin large
there are alot of little plastic clips that will be brittle. i suggest investing in the tool to lessen the chance of damaging the panel.
Old 04-01-2014, 04:28 PM
what is the tool? never heard this before
Old 04-01-2014, 05:32 PM
downhiller's Avatar
livin large
door panel removal tool
http://www.rakuten.com/prod/michigan...FY0-MgodoT8AAQ
Old 04-07-2014, 05:36 AM
BMWFatherFigure's Avatar
Old School
Also check that the window rubber has not got twisted in the frame somewhere. My E32's are prone to that.
Current:
E38 Parts Car
Previous:
Old 04-08-2014, 12:03 PM
you won't believe this but a window switch on the console fixed the window. It runs just like the rest of them now! thanks guys for all the sugestions
Old 04-08-2014, 02:34 PM
downhiller's Avatar
livin large
huh.....thats weird. havnt seen that yet.
Old 05-02-2014, 08:43 PM
E30 hobby car E30 hobby car is offline
Mein Auto: 1986 325e 4 door auto
my front passanger window motor is screaming at me. I was told the bushing become fused somewhere.
Anyone know of a rebuild step by step?
Old 05-07-2014, 09:45 AM
JessicaJ JessicaJ is offline
Mein Auto: 1991 BMW 318i Convertible
So are you saying you just bought a new switch for the console and replaced the old one? Since I'm in a 'vert, I have no switch for the rear windows BUT the one on the console, and my rear windows are on the slower side. Just wondering if that would make a difference for me.
Old 05-07-2014, 10:39 AM
try it Jessica just replacing the console switch did the trick! Just pry the switch up gently from the console I used my small pocket knife and fingernails. The connector is longer in the back than the front so when you get it coming out raise the front first and slide it forward the whole switch will come out. gently pull the wires to give you enough room to unclip the connector (also my small pocket knife hepled pry it loose) then simply do the reverse order. I have 5 or six window switches laying around so I made sure the switch worked before I pressed it back down. you will see how it clips back in. on a scale of 1 to 10 difficult it is about a 1-
