Old 04-02-2014, 10:09 AM
ttraynor ttraynor is offline
Mein Auto: Z# M Coupe
Quaiffe Differential in Z3 M Coupe?
I have bad diff chatter and pretty much isolated it to the clutch pak. The subframe is perfect. Ireland bushings installed. New clutch, tranny mounts, etc.
Can I upgrade/replace the clutch pack guts--or do the Quaiffe--assuming there is a fitment.
I love the Quaiffe on my old GTI and it is bulletproof.
SO: IS there a fitment? Best source? Anything else I should know?
Old 04-02-2014, 10:45 AM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Not sure about the availability of the Quaiffe, but your rear diff is not that difficult to rebuild. Chances are by now, it is running as an open diff as the clutches are worn out. Here is where to get replacement or upgraded parts for your diff. There are videos giving step by step instructions.
http://www.bimmerdiffs.com
They are made by a fellow Z member.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
