Old 04-07-2014, 10:55 PM
bimmerfestfan bimmerfestfan is offline
Mein Auto: G12
428i: What causes "burning smell" after spirited driving?
I put her on "Sport" mode and floored it a couple of time with revs reaching 6k or so. When I got back to my garage, I noticed the typical "burning smell" that happens after hard driving. What causes this "burning smell"? Burnt off carbon deposit from city driving?
Old 04-08-2014, 01:28 AM
HFW003's Avatar
HFW003 HFW003 is offline
Mein Auto: 2013 Havana 328I
Could be the brakes, they do get quite hot and emit a nasty smell!
Currently - Havana 328 Modern Line, Pro Nav, Xenons, HK sound, sports seats, VSS, adaptive suspension, 19" 401's and other bits and pieces.
Ride - 2014 Panigale 1199 S with Termi slip ons and lots of CF goodies
Old 04-08-2014, 01:33 AM
Mein Auto: G12
But then I was easy on the brakes. I floored it from 0-60 (PSL) and then just let it coast to the next red light or corner and then floored it again. Rinse and repeat.
Old 04-08-2014, 07:17 AM
carzaddict carzaddict is offline
Mein Auto: 328 x-drive
burnt carbon is most likely the case. brakes would be next
2013 328i X-Drive, M-Sport, tech, cold weather, PCD, Backup Cam, Sports Auto Transmission (coded), Launch Control (Coded) - BMS Stage 1
2012 Jaguar XJL
Old 04-08-2014, 10:04 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Hot lubricants.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 04-08-2014, 04:06 PM
ebs0712 ebs0712 is offline
Mein Auto: 2014 3 Series Wagon (F31)
If your car is newish it could simply be the burning of the paint on the exhaust system. When driven "harder" in sport mode it probably caused more exhaust heat.
2014 328xi Wagon (F31)
2017 430xi Grand Coupe (F36) European Delivery
BMW CCA #257
Old 04-08-2014, 06:29 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
I agree.
Even after aggressive track driving with my former cars (M3, etc.) I don't recall any "burning" odor after leaving the track (this would have alarmed me) other than normal brake heating...and I was in the BMW CCA "A" run group in high temp. desert conditions (Buttonwillow, CA).
A new car would be inclined to do this...all sorts of "burn off" odors.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 04-08-2014, 10:40 PM
Mein Auto: G12
My car only has around 1700 miles. I noticed the carpet lining of the trunk feels noticeably warmer after harder driving. So it must be from the exhaust system.
I noticed the oil temperature runs a tick higher too on Sport mode. I've heard the M-Sport package gives better cooling. Does it have a better oil cooler or just more aggressive front end design that gives better air flow to assist the cooling?
Old 04-08-2014, 11:40 PM
inChargeOfIT inChargeOfIT is offline
Mein Auto: 2013 335i
It's likely sulfur smells coming from your exhaust and is normal. Sulfur rich fuels (try a different gas station) could cause it, and the amount of sulfur in the fuel varies state to state, but it's likely just normal smells from your new catalytic converter. As your catalytic converter 'ages' the smells should soften up.
Fuel additives, software tuning that alters the fuel/air mixture, and catless/high flow catted downpipes, etc can also greatly increase the 'rotten egg' type smells. If the smells happen frequently (under normal driving conditions), and you have burned through a tank or two of gas from a different stations, you may want to take it in and have it checked out as it could indicate a bad cat.
However, if the smells resemble burnt plastic or burning oil you should have it checked out. I had a car go up in flames because a fog light came out of its socket and melted the bumper area.
Old 04-09-2014, 01:04 AM
Mein Auto: G12
It smelt like semi-burnt toast. The kind of smell you get from heated oven.
Old 04-09-2014, 03:33 PM
raqautle raqautle is offline
Mein Auto: 2011 E90 328xi
I believe it's both and a bigger coolant tank but I'm not a 100% sure.
My primary car: 2014 F32 435i xDrive MSport
Secondary car: 2012 F10 528xi Luxury Line
Old 04-10-2014, 10:17 AM
madhotm3's Avatar
madhotm3 madhotm3 is offline
Mein Auto: '14 535d M-Sport
what he said ... very well explained!
I'd say you should take it in and have the dealer check it out.
Old 04-10-2014, 11:17 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
There's an extra radiator in the m-sport - I forget if it's for oil or coolant though.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
