Old 04-07-2014, 07:36 PM
Mike Stiggers Mike Stiggers is offline
Mein Auto: BMW 2007 328i
2007 328i just stopped and will not start
Hello all. I have a big problem. I'm on vacation near Savannah, Ga. My 2007 328i just stopped and will not start. It seemed to be the battery as i pushed the start button, the sound of start up just got weaker and weaker until there was no sound at all. The service light is on.
If I buy a new battery and install, will that get me back on the road? Need HELP.
Old 04-08-2014, 07:03 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest. I've moved your question over to the E90 3 series forum as that is your chassis code. Try searching around in this forum for other members who might have had a similar issue. If your car was cranking and not firing that doesn't sound like the battery. Can you get a jump? That would be the easiest way to start tracking down the issue.
Take a look at the new member guide to get a better sense of how to use the site - http://www.bimmerfest.com/forums/sho...d.php?t=384118
Tim
Old 04-08-2014, 07:19 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
View & do
Old 04-08-2014, 08:47 AM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
1) See if car jumps
2) If yes, most likely the battery. Replace battery with a correct replacement and make sure the battery is registered with the onboard computer
3) If it does not jump, bring car in for diagnostoc.
Old 04-08-2014, 03:15 PM
FF2Skip FF2Skip is offline
Mein Auto: '98 323is
Wasn't there a battery cable recall for 2007?
Old 04-08-2014, 04:19 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Yes, but eventually, it will have to see a dealer or an indie so the proper battery coding can be completed.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 04-08-2014, 06:45 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
If you buy a battery do not use battery back up
If you buy a battery do not use battery back up or
let anybody else use battery back up when installing the
battery it will blow fuses.
If you are getting weak turnover check the battery first.
You wouldn't be getting that with the cable problem.
You don't need to register the battery immediately but it should
be done .
Putting a charge on and seeing what happens would be a good
first step. Since you are stranded you need somebody to take
some measurements.
Old 04-12-2014, 07:23 PM
islandbimmers islandbimmers is offline
Mein Auto: E90 E83
I have the same problem going on, I knew the battery on my 07 E90 was going to need to be replaced. We alternate cars so I don't drive her everyday, always starts fine but not as quick as the wife's.
Friday I drove about 5 miles to doctor then made several stops, all the while with A/C blasting and maybe jamming to much for an old guy. The last stop was just that, came out of store and inserted fob, hit button...nothing, well a half crank.
Called wife, got a ride, went back 3 hours later...nothing, now brake pedal won't depress correctly to crank. So I had the car flatbedded to my house, went to dealership the next morning and bought the Advanced BMW Battery Charging System. Hooked it up carefully doing everything right, after 6 hrs it signaled 80% charge, another 7 hrs and it read fully charged and on standby.
So this morning I went to crank her and nothing same thing, have done a lot of reading and seems it could be redoing codes or starter...Ikes! Flatbed coming back Monday morning and I am not happy.
Should I take her close by to my very good Indy or pay the long tow to BMW?
Old 04-13-2014, 05:35 AM
Mein Auto: '06 AW 330xi
Try jump starting.
It could also be an alternator issue. Possibly starter but I'm leaning toward alternator.
Old 04-13-2014, 05:42 PM
Mein Auto: E90 E83
Nervous about where to take her, will the Indy have everything needed to diagnose?
Old 04-13-2014, 09:16 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
should be, take her to Indy and enroll in AAA...
2014 X1 28xi, 2011 X3
2006 330xi E90 158k miles.
2003 330xi E46
