Go Back   Bimmerfest - BMW Forums > Welcome to Bimmerfest > BMW News Articles and Announcements
Read the latest BMW headlines and discuss them with your fellow bimmer enthusiasts!
Old 10-26-2004, 05:43 AM   #1
The new 3-series Sedan -- March 2005
pixA4
Guest
Posts: n/a
Show Printable Version Email this Page
pixA4
The new 3-series sedan
Press Release
The new BMW 3 Series
The fifth generation of the benchmark small executive car
BMW Great Britain has announced the first details of the new BMW 3 Series range to be launched in spring 2005.
"The new 3 Series faces the daunting task of upstaging what is the defining car of its generation and market sector. With engine technology and a focused design strategy at its core, the new 3 Series looks set to do just that. Once again, the new 3 Series sets a new benchmark for small executive cars and I am confident it will be a great success in both the corporate and retail markets," said Jim O’Donnell, managing director of BMW Great Britain.
The new BMW 3 Series delivers an even more dynamic driving experience than its predecessor, accelerates faster and achieves a higher top speed but not to the detriment of economy, with the new 330i delivering improvements in fuel consumption while the 320i and 320d match their predecessors.
Powering the fifth generation of new BMW 3 Series is a range of engines all married to a standard six-speed manual gearbox (six-speed automatic optional). Topping the range is the BMW 330i featuring the most powerful, yet lightest, six-cylinder engine in its class – the same engine that powers the recently launched BMW 630i Coupé. Delivering 258bhp and 300Nm (221lb-ft) between 2,500 and 4,000rpm, this engine powers the car from zero to 62mph in just
6.3 seconds and on to a limited top speed of 155mph. However, this is not at the expense of economy, with the new 330i delivering 33.5mpg combined fuel consumption.
These levels of performance are made possible by a number of significant developments in engine design and construction. The engine sees BMW use magnesium in its construction process for the first time in large-scale series production. The crankcase jacket, bedplate and cylinder head cover are all made from magnesium, which weighs 30 per cent less than aluminium.
Additionally, the new 3.0-litre unit is the first six-cylinder engine to feature BMW’s patented VALVETRONIC induction system. First seen on BMW’s V8 engines and more recently offered as standard on the Hams Hall four-cylinder petrol engines, VALVETRONIC infinitely varies the intake valve opening times and, when combined with Bi-VANOS variable camshaft timing, delivers the optimal fuel efficiency and engine response.
Also joining the six-cylinder model range in spring 2005 will be the 325i, delivering 218bhp at 6,500rpm and 250Nm (184lb-ft) at 2,750-4,250rpm.
The new 3 Series range will also feature a two-litre diesel and a two-litre petrol variant at launch. The BMW 320d, currently the UK’s most popular 3 Series model, features second-generation common rail diesel technology and a variable vane turbocharger to deliver 163bhp and 340Nm (251lb-ft) of torque. This provides the car with the best of all worlds. Acceleration to 62mph is achieved in 8.3 seconds with a top speed of 140mph. While delivering this level of performance, it also achieves 49.6mpg on the combined cycle and, as an additional benefit to the company car driver, is EU4 compliant.
The engine in the new 320i is based on that of the outgoing 318i, but with enhancements to the induction and exhaust systems. Also benefiting from BMW’s VALVETRONIC and Bi-VANOS systems, the new 320i offers 150bhp at 6,200rpm, with a maximum torque of 200Nm (147lb-ft) achieved at 3,600rpm. This enables the car to accelerate to 62mph from standstill in 9.0 seconds, achieve a top speed of 137mph yet still deliver a frugal 38.2mpg.
Further four-cylinder 3 Series variants will follow during the course of 2005.
Ensuring that the power and torque remain in check is the responsibility of the new DSC+ system (on six-cylinder models – standard DSC on four-cylinder models). Effectively an evolution of the familiar DSC traction control system, DSC+ offers a range of benefits, including Brake Standby that pre-tensions the brakes when the driver quickly removes the pressure from the accelerator pedal. Soft Stop is also incorporated which modulates the brake application to prevent the nose of the car from ‘diving’ when travelling slowly. Also included in DSC+ is a Start-Off Assistant that uses the clutch to prevent the car from rolling back on a hill-start and a brake detector that ensures the discs are kept dry and responsive on wet roads.
Also assisting the car’s agility is BMW’s Active Steering system, available for the first time in a car of this class. Previously only available on larger 5 and 6 Series models, Active Steering is offered as an option on six-cylinder models and resolves the conflict between low-speed agility and higher-speed stability by delivering a speed-proportional steering ratio. Active Steering also brings a number of key safety benefits. In conjunction with the DSC+ system, if the car detects oversteer, Active Steering applies a small amount of positive steering angle to bring the rear of the car back into line. Additionally on the new
3 Series, when applying the brakes on a surface with differing grip levels such as snow or ice, Active Steering intervenes to stabilise the car more precisely and quickly than the driver is able to do manually.
Supporting these steering and traction control systems is a chassis that has been tuned to deliver optimal driving dynamics on all road conditions. With BMW’s trademark front engine – rear-wheel-drive layout and near-perfect 50:50 weight distribution, the new 3 Series feels nimble and agile on the road. Its double-joint spring strut front axle is made completely of aluminium, minimising the unsprung mass of the car and reducing road noise. The new five-arm rear axle, first seen on the new BMW 1 Series, delivers excellent ride comfort.
The new 3 Series body is stiffer yet lighter than that of the outgoing model. Thanks to a new joint and crossbar arrangement for the car’s load-bearing structure, the bodyshell stiffness is increased by 25 per cent over its predecessor.
The inherent rigidity of the steel bodyshell enhances the new 3 Series’ class leading safety levels. With the addition of six airbags as standard, including curtain head airbags for front and rear occupants, the car is expected to receive a five-star Euro NCAP rating. It is also one of the first cars in the world that is fully prepared for the rigorous side impact requirements in North America as well as the US high-speed rear impact test.
Also supporting these high standards of safety are a number of familiar systems from other BMW models. Brake Force Display is standard for the first time on 3 Series Saloon models, offering two stage brake lights. Brake lights illuminate normally in average driving conditions but during an emergency stop or when the ABS braking cuts in, the area of brake light illumination increases to warn those travelling behind of the situation ahead.
Adding further to safety levels are Run-flat tyres, available for the first time on 3 Series models. Like the 1, 5 and 6 Series models, Run-flat tyres are offered as standard, and with the recent developments in Run-flat technology, the car can now be driven for an astonishing 150 miles at 50mph with up to four punctured tyres. This allows the driver to complete almost any journey before replacements need to be sought.
Like the levels of standard and safety equipment, the proportions of the car have also grown over its predecessor. Measuring 4,520mm (+49mm) in length, 2,760mm (+35mm) in wheelbase, 1,817mm (+78mm) in width and 1,424mm (+9mm) in height, the new BMW 3 Series offers a spacious and light cabin. With occupants cosseted by their surroundings, a driver-orientated dashboard layout places all the primary controls at the driver’s fingertips while the secondary controls are conveniently and ergonomically accessible. Rear occupants benefit from an increase in head, shoulder, elbow and leg room.
For those customers opting for either Business or Professional navigation systems, BMW’s iDrive operating concept comes as standard for the first time in a car of this class. Replacing the conventional single hood dashboard layout, the display screen sits centrally on the dashboard in a second binnacle to deliver navigation information alongside on-board computer information, entertainment and climate control adjustments and Check Control messages.
Also available for the first time on a BMW in this class is Comfort Access. All cars receive a newly designed key that replaces the conventional blade-type key but with Comfort Access the key contains an ID Sensor that the car recognises from a short distance away. On recognition, the doors are unlocked automatically and the car can be started with one push of the starter button. The Comfort Access system also works in tandem with BMW’s familiar key memory system to ensure that the seating position, door mirrors, personalised air conditioning settings and radio reception are automatically adjusted to the current driver’s settings before they enter the car.
For more information please see the Official E90 Thread here!
This article has been viewed 9019 times.
Similar Threads
real 1 series pics.... *56K Warning* Teej E82 / E88 1 Series (2008 - 2013) 42 03-23-2004 05:22 PM
OEM clear lenses for '99 - '01 BMW 3 series sedan pgp78 Classifieds 0 09-12-2003 05:43 PM
OEM clear lenses for '99 - '01 BMW 3 series sedan pgp78 Classifieds 3 09-12-2003 05:42 PM
Clears for the 2002 3 series sedan! Cyclone 3 Series / 4 Series 31 02-06-2002 10:34 AM
