Inspection 2 at 57000 miles, what's involved? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 10-26-2004, 07:42 AM
cssmgt cssmgt is offline
BMW325cic noob
Send a message via AIM to cssmgt
Mein Auto: 325cic
Smile Inspection 2 at 57000 miles, what's involved?
Hey group,
I inquired about an "inspection 2" just to prepare my wallet. In about 9K miles I'll be due.
They told me it will cost around $700.
Does anyone know what actually is done for $700, besides the oil change?
I've already had my pads, rotors, tires changed at 48K. All under warranty. Long story.
Alignment has been done, etc.
The car was purcahsed as a "certified" pre-owned. So I am curious what is done for the pre-owned certified part.
Will things be done in the "inspection 2" that should have been done as part of the "certification" process. Just curious.
Any insight into this is appreciated.
If there are somethings I can do myself, such as the oil change, I rather save the money.
Old 10-26-2004, 09:19 AM
Nde's Avatar
Nde Nde is offline
Mein Auto: 97-328IS and 04-325CIC
If you log into Owercircle at BMWUSA. It will tell you what Inspection 2 is for your model. Here's my for example. I owned a 323CIC 04. (Bad format, I just copy and paste)
BMW Inspection II
Undercarriage
Change oil and oil filter while engine is at operating temperature.
We recommend BMW High Performance 5W-30 Synthetic oil, p/n 07 51 0 017 866
Check transmission for leaks.
Check rear axle for leaks.
Half shafts: Check for leaks at flexible boots.
Visually check fuel tank, lines and connections for leaks.
Check condition, positioning, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks. Check p/s fluid level; add fluid if necessary.
Check overall thickness of front and rear disc brake pads using special tool. Record results. If replacement is necessary*:
Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel centering hubs. Check thickness of parking brake linings only when replacing rear pads. Record results.
Check brake and clutch system connections and lines for leaks, damage, and incorrect positioning.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage and joint disc.
Check parking brake actuation. Adjust if necessary.
Check all tire pressures (including spare). Correct if necessary. Check
condition of tires (outer surfaces [left/right]), tread wear and pattern; in
case of uneven tread wear readjust wheel alignment if requested(to be
invoiced separately.)
Note: If requested rotate all four road wheels as instructed and rebalance.
(invoiced separately.)
Inspect entire body according to terms of rust perforation limited warranty (must be performed at least every two years).
Engine Compartment
Read out diagnostic system.
Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary.
Check level of brake and clutch fluid in reservoir. Add fluid if required.
Replace brake fluid every 2 years (timing interval begins from vehicle's production date).*
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner operation.
Replace microfilter.
Note: reduce replacement interval in dusty operating conditions.
Reset Service Indicator.
Replace intake air cleaner element.
Note: Reduce replace interval in dusty operating conditions.
Body/Electrical Equipment
Check battery state-of-charge, and charge if required.*
Check lighting system, i.e., headlights, foglights, parking, back-up, license-plate, interior (including map reading lights), glove box, flashlight, illuminated make-up mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wipers and washer system(s);wiper blades, washer jet positions.
Check condition and function of safety belts.
Recharge or replace batteries for remote controls in all vehicle master keys.
Check central locking/double lock.
Check operation of all latches.
Check heater/air conditioner blower fan, rear window defogger.
Check rear view mirrors.
Visually examine the SRS airbag units for torn covers, obvious damage or attachment of decals, decorations or accessories.
Activate automatic roll-over protection system (if equipped) via diagnostic link.
Note:First remove hardtop/lower top.
Lubricate the convertible top sliding hinge covers using a non-silicone spray.
Final Inspection
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission.
Old 10-26-2004, 10:56 AM
BMW325cic noob
Mein Auto: 325cic
So basically for $700, all they do is "check" the car all over, which I just had them do due to a warranty issues.
Also they:
Replace some filters
Change Oil
charge or replace master key batteries
That's a ridiculous price for this don't you think?
So at roughly at $75/hr and some parts, thats almost 9hr's worth of work.
That's BS in my opionion.
Anybody do this stuff themselves?
Old 10-26-2004, 03:46 PM
LDV330i LDV330i is offline
Mein Auto: 2014 335i M-Sport EB
That is cheap. Here in Houston the going rate is $100/hr.
Old 10-27-2004, 07:50 AM
Black2000328i Black2000328i is offline
Mein Auto: 2000 328i
cssmgt. In my manual, it also states that they
change the spark plugs and oxygen sensor.
I think they may change the fuel filter along
with the coolant. In parts your looking at :
6 spark plugs
fuel filter
air filter
micro filter
oxygen sensor
7 qts. of synthetic oil
oil filter
4 qts. of coolant
brake fluid
Call the dealer and have them give you a price
on the parts . It may be around $300. I think
these engines have 4 oxygen sensors
If thats the case then 4 to 5 hours of time plus
the parts should put you around the $700 mark.
Old 10-27-2004, 09:37 AM
vm vm is offline
Mein Auto: 330i
I am sure that the $700. does not include O2 sensors. The thing is that the e36 also needed a diff. fluid, trans. fluid, and spark plug changes and when the e46 came the Insp prices stayed the same. So basically they are charging you for:
Microfilter change
Air Filter change
Oil and filter change
All the "checks" listed by Nde
And yes, I do this myself and save $600+ dollars
Old 11-04-2004, 12:59 PM
madblznguy madblznguy is offline
Mein Auto: 330 CI
6 spark plugs
fuel filter
air filter
micro filter
oxygen sensor
oil filter
4 qts. of coolant
brake fluid
You're from Canada so it could be different but here in the US you don't get half that stuff...
you get
oil change
brake fluid flush and the rest is all just checking stuff
oh and a microfilter and an air filter woopie!
oh and its 790$ here at my dealer in NJ RIPOFF!!!! I will do my brakes, spark plugs, oil, and microfilter for about 150 bucks a savings of 640$
Similar Threads
Inspection I more than 15k miles MC 3 Series & 4 Series 2 08-23-2004 09:42 PM
Miles on odometer at delivery: how many? CMOS Ask-A-BMW-Dealer 7 10-16-2002 12:10 PM
20 miles of country road Dr. Phil General BMW Questions 25 08-01-2002 06:54 AM
Oil change every 7500 miles??? Nick 325i 3 Series & 4 Series 14 01-23-2002 10:59 AM
Inspection II @ 40K miles right? JD General BMW Questions 24 01-16-2002 03:41 PM
