*very* sluggish start - not battery - Bimmerfest - BMW Forums
Old 04-09-2014, 10:57 AM
cjmuuunoz cjmuuunoz is offline
Mein Auto: 2007 328i
After extensive searching through forums, I haven't seemed to find a problem quite like mine. Not that I thnk I'm special or anything...
2007 328i w/ 115k miles
Semi-slow start for past few months, knew car had original battery on it that would need replaing.
On a cold start yesterday morning, put key in, foot on brake, push to start, radio/lights came on, car sounded as though it was starting then just sputtered and died out, footbrake locked up, steering wheel locked up, service engine indicator displayed.
Took key out, tried again, same result. Try 3 - worked.
Took the car into the shop, they put a battery load on it and it was fine, mechanic though that was because I had driven it though and alternator was able to charge battery.
He checked the error codes and saw a battery failure.
Battery was replaced and car ran fine the rest of the day.
This morning, same problem on the cold start.
Any ideas? Starter? Alternator? Anyone else have this problem?
Old 04-09-2014, 11:36 AM
Mein Auto: '06 AW 330xi
Sounds like an alternator issue.
But you should replace the battery anyway. A weak battery will strain your electrical system and cause more issues.
Old 04-09-2014, 11:46 AM
Thanks. Yeah, had the battery replaced yesterday which is why I was so sad when it happened again today.
I'm thinking alternator or starter... maybe something is wrong electronically that is draining the battery while it is sleeping at night that I'm unaware of?
Hopefully my Indy guy can diagnose it tomorrow.
Old 04-09-2014, 08:23 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well, before replacing the battery alternator should have been checked. Was it?
View & do test below. Result?
Old 04-14-2014, 09:39 AM
My car has spent the past 3 days at the shop....
The mechanic now thinks its the fuel pump. He thinks that there isn't enough fuel pressure on cold starts to get it going. After I sit there and try a few times, the pump eventually builds enough pressure to start..?
Would this make sense seeing as though the start-up issue only occurs after the car has been sitting (6+hours)?
Once I get it started, it will start throughout the day on the first try just fine, just can't let it sit too long.
Got a ~$600 estimate to replace the fuel pump. What do you all think?
Old 04-14-2014, 09:35 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
The fuel pump is accessed by removing the rear seat. Depends on the price of the fuel pump but he shouldn't have to guess. The Bentley manual shows how to test the fuel pressure with a fuel gauge tester in the engine compartment (5.0 bar +/- 2.9 psi).
Old 04-16-2014, 03:00 PM
After many diagnosis misfires, it is the dreaded eccentric shaft sensor.
Shop is charging 1200 for parts and labor.
Old 04-16-2014, 04:29 PM
Banned
Mein Auto: 2007-335 HTC
Sorry but I thought the HPFP was a big problem and a Warranty issue
alternator, battery, service engine light, starter
