Old 04-13-2014, 08:36 AM
Abbyguy Abbyguy is offline
Mein Auto: 2011 323i
Sound from rear wheel well pass side
Twice lately after shutting down engine I heard a sound coming from the rear pass wheel area when I just happened to walk by the rear of the vehicle. I crouched down to listen closely and thought it was the sound of air escaping from the tire. That was not the case. It continued for about less than a minute then stopped abruptly with what sounded like a pop. On the second occasion I know the battery is located in that area so I quickly opened the trunk and exposed the battery enclosure. The sound didn't appear to emanate from that area. Quickly I went to the wheel well again, the sound was still there and then stopped. Doesn't occur every time but I check each time now when parking the car in the dead silence of the underground parking area when there is no ambient noise present. Anyone else experience this sort of thing? As always feedback is appreciated.
Old 04-13-2014, 09:07 AM
Mein Auto: '06 AW 330xi
It's the DMTL pump pressurizing the EVAP system....perfectly normal.
It's an emissions related system.
Old 04-13-2014, 09:41 AM
Thanks...appreciate the response and knowing it's normal.
