E30 (1982 - 1993)
Old 04-15-2014, 11:51 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
My E30 325e build thread
Hello everyone, My name is Jesse and this is my 87' 325e.
So I have owned bmw's for the past 6 years or so and was itching for a DD so I could keep the miles off my e36. I searched for well over a year and finally spotted a red e30 sitting on a roll back in the back of a guys yard. I stopped in and spoke to the owner. He said they bought the car 6 years ago from an old lady and have yet to be able to get the car running. The interior of the car was immaculate, including a crack free dash, 149,xxx miles on it and a 5 speed. The guy told me I could have the car for $800. I showed him $650 and he took it.
After getting the car home I bought a battery and attempted to start the car, just cranked and cranked. I had spark but no fuel. I figured since the car sit for 6+ years I would start replacing things that would need to be replaced anyway. I replaced the internal and external fuel pump, along with a new fuel filter. So now I could hear the fuel pump kicking on! Great! Still wouldn't start. I bought an extra dme and still no start. Then it hit me, how clogged those injectors must be. Found a used set on craiglist for $20. Threw them in and bam! Started right up!
Ok now the car is running. Went to pull out of the driveway and take it around my block, went to hit the brakes and the pedal went all the way to the floor! Installed new brake lines, now we have brakes. Ok now the car is running solid and in good driving condition, off to fix the little things.
What wasn't working and/or issues:
1. A/C
2. Three of the power windows.
3. Radio
4. Leaky fuel when filled up
5. windshield washers wouldn't spray
6. oil leak
7. heater/ac fan only worked on 4
What needed/should be done before driving daily.
1. water pump
2. timing belt
3. aux fan
4. t-stat.
So replaced the valve cover gasket, water pump, aux fan, t-stat when I did the timing belt. Took about 6 hours taking our time.
Bought a used radio off ebay and installed it. Installed new windshield washer valve to fix the no spray. Blower resistor motor, now works on 1-4. Installed 134a retrofit kit and charged the a/c, now is ice cold. So all that was left is to fix the windows and fuel leak.
For the windows I started moving around switches to see if it was just bad switches, didn't fix the issue. Decided to take the door panels off and take a better look. The window motor and regulator tracks were super dry, greased them and sprayed some wd40 into the window motor. After letting the grease and wd40 set for a few minutes I grabbed the emergency window allen head tool and began to work the windows while pushing the window buttons. After about 45 minutes the windows were going up and down on there own!
The tires were also dry rotted bc of sitting for 6 years, picked up a set of borbet wheels with new tires for $200!
After driving the car for about 2 weeks, the gears in the cluster broke. I replaced the gears for about $25 and now miles are recording again!
So as of today the only thing left to fix is the leaky fuel issue when filled all the way up. Hopefully going to tackle that this weekend!
Purchase of the car $650
parts to fix everything, including the price of registration and the new wheels/tires. $500
$1150 total on a now reliable DD with 150,000 miles
This is my first write-up, don't bash me too bad! Pics attatched are from the day I picked her up.
ID:	433863   Click image for larger version
ID:	433864   Click image for larger version
ID:	433865   Click image for larger version
ID:	433866   Click image for larger version
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 04-15-2014, 11:53 AM
B1MM3R's Avatar
Jesse Moon Bayne
Here are some pictures of how she sits today. One pre bumper tuck and one post bumper tuck
ID:	433869   Click image for larger version
ID:	433870   Click image for larger version
ID:	433871   Click image for larger version
ID:	433872   Click image for larger version
ID:	433874   Click image for larger version
Jesse
2001 330i DD
Old 04-15-2014, 12:18 PM
hornhospital's Avatar
D'oh, You Kids!
Your red car almost makes me want a sedan. Almost.
Nice write-up, Jesse.
Quotes to live by:
Old 04-15-2014, 12:23 PM
B1MM3R's Avatar
Jesse Moon Bayne
I LOVE my sedan! That was one of the conditions my wife gave me on getting a DD is that he must have 4 doors haha.
Thanks Ken!
Jesse
2001 330i DD
Old 04-15-2014, 12:36 PM
beammeupscottie beammeupscottie is offline
Mein Auto: 1989 325iC
Love my Sedan, wish I was in it as cheep as you are!
Life is like a roll of toilet paper...the closer you get to the end the faster it goes. So drive an E30 everyday
1989 325iC Alpineweiss II manual 5 speed Curent ride
1990 325i Glacier Blue 4 door Auto, 1987 X 2 (Black 325ic convertable & Granite silver 325i coup) Gone but never forgotten
Old 04-15-2014, 03:28 PM
downhiller's Avatar
livin large
fuel problem is gunna be either the fuel pump gasket, filler tube or vent tube. most likely the fuel pump gasket
Old 04-15-2014, 03:37 PM
B1MM3R's Avatar
Jesse Moon Bayne
Ok, so I have these two hoses. Which gasket you talking about?
hose pn: 16121180402 and 16131178336
ID:	433895   Click image for larger version
ID:	433896   Click image for larger version
Jesse
2001 330i DD
Old 04-15-2014, 04:09 PM
downhiller's Avatar
livin large
i believe its number 10. should just be a o-ring
Old 04-15-2014, 04:20 PM
B1MM3R's Avatar
Jesse Moon Bayne
Went ahead and order part 10 & 6, only $12 shipped. Thanks for the info.
Jesse
2001 330i DD
Old 05-05-2014, 11:04 AM
B1MM3R's Avatar
Jesse Moon Bayne
Fog light delete done and installed ellipsoids.
Also just ordered some 16x8 et20 wheels!
ID:	437634   Click image for larger version
ID:	437635   Click image for larger version
ID:	437636   Click image for larger version
Jesse
2001 330i DD
Old 05-09-2014, 08:21 AM
B1MM3R's Avatar
Jesse Moon Bayne
Picked these up, bilstein shocks and eibach pro springs off of an e30 m3.
$180.
ID:	438436   Click image for larger version
Jesse
2001 330i DD
Old 05-15-2014, 02:41 PM
B1MM3R's Avatar
Jesse Moon Bayne
Wheels and tires are in. Should have the suspension, wheels and tires on this weekend!
ID:	439864   Click image for larger version
Jesse
2001 330i DD
Old 05-19-2014, 08:28 AM
B1MM3R's Avatar
Jesse Moon Bayne
So got the tires mounted and balanced on my new wheels this weekend and they turned out great. I test fitted them on the car and decided that I don't want to go with a drastic drop since this is my daily driver. Going to sell these eibach's and get a milder drop. Also fixed my fuel leak and can now enjoy less stops and the fuel station!!!! Here's some pics
Some pics have the center caps and some don't, still waiting on the bmw emblems to arrive.
ID:	440591   Click image for larger version
ID:	440592   Click image for larger version
ID:	440593   Click image for larger version
ID:	440594   Click image for larger version
Jesse
2001 330i DD
Old 05-19-2014, 08:29 AM
B1MM3R's Avatar
Jesse Moon Bayne
ID:	440597   Click image for larger version
ID:	440598   Click image for larger version
ID:	440599   Click image for larger version
Jesse
2001 330i DD
Old 05-19-2014, 08:42 AM
B1MM3R's Avatar
Jesse Moon Bayne
Jesse
2001 330i DD
Old 05-19-2014, 01:54 PM
cmac2012's Avatar
cmac2012 cmac2012 is online now
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Excellent score for $650. I'm a sedan man myself. Only way to go.
Old 05-19-2014, 06:00 PM
downhiller's Avatar
livin large
so is that with the coil overs or stock suspension
Old 05-20-2014, 08:08 AM
B1MM3R's Avatar
Jesse Moon Bayne
Stock.
So yesterday on my way home from work the car started running like crap, zero issues untill now. When stopped at idle, there is a knock/tapping noise, doesn't sound like in engine. Believe its because the engine is shaking at idle. Also when I give the car gas under load it shakes like the car is falling apart. Hoping just a vacuum leak or something simple. Didn't have time to look at it yet. Any thoughts?
Jesse
2001 330i DD
Old 05-20-2014, 06:04 PM
downhiller's Avatar
livin large
broke motor mount, 1-2 fouled plugs, hole in a piston. theres alot that could do that.
id start with a power balance test, which remove one spark plug wire and start the engine, if its worse, put wire back on and go to the next. find out which one doesnt effect the idle/shaking. then thats the cylinder to focus on. if all have the same result (does exactly the same to all) try fuel pressure test and compression test
Old 05-21-2014, 08:14 AM
B1MM3R's Avatar
Jesse Moon Bayne
Thanks Downhiller. I replaced the plugs yesterday with no help. Talked to our local E30 genius and he said it's one of three sensors causing the issue. He said the knock I'm hearing is from the transmission input shaft making noise because the car is running so rough. He said could be AFM, temp sensor or the third one I can't remember. He has a few parts and going to bring them and see what we can figure out this evening.
Jesse
2001 330i DD
Old 05-22-2014, 09:08 AM
B1MM3R's Avatar
Jesse Moon Bayne
So I started unplugging each ignition coil and found that the misfire is on cylinder 3 only. I popped of the valve cover and the rocker arms look good. My next step was a compression test and got 150 across all 6 cylinders, that was a relief. I checked spark on the ignition coil and it's good. So I have spark and good compression. Time for some injectors, ordered a used set but wont be here untill next week. I will update then.
Jesse
2001 330i DD
Old 05-22-2014, 10:02 AM
Ken@BavAuto Ken@BavAuto is offline
Bavarian Autosport
Mein Auto: 1989 325is
Did you verify that you have spark from the # 3 plug wire? A bum wire would be easier than injectors to change. For a mild drop I would look into the H&R OE sport springs. I have a set on my 89. They were really intended for big bumper cars on my 89 it dropped the rear about an inch more the front which I compensated with thicker spring pads. And up front I actually wound up using E90 spring plates to lower it a bit more. But I've seen them on big bumper cars and they drop the car like 3/4"-1". And they ride quite nice.
CONTACT US
WEB: http://www.bavauto.com/ | E-MAIL: kenb@bavauto.com | PHONE: 800-535-2002
HOURS (EST): Monday - Thursday 8AM - 9PM | Friday 8AM - 7PM | Saturday 9AM - 4PM
CONNECT WITH US
Facebook | YouTube | DIY Tech Blog | Twitter
Old 05-22-2014, 11:08 AM
B1MM3R's Avatar
Jesse Moon Bayne
Yea, I checked the plug wire and it has spark. I actually found a set of your Bavauto springs local for $120 so I grabbed them!
Jesse
2001 330i DD
Old 05-28-2014, 08:44 AM
B1MM3R's Avatar
Jesse Moon Bayne
Nasty gas. I see what's clogging my injectors! Started to clear up and get less orange l. Going to ad 5 more gallons sometime this week and drain from behind filter vs in front and see if cleaner. If cleaner going to replace filter and clean injectors and go from there. Also going to change the filter (cheap $5 one) every fill up for next 4-5 times. Any thoughts/suggestions?
Jesse
2001 330i DD
Old 05-29-2014, 08:04 AM
B1MM3R's Avatar
Jesse Moon Bayne
Gas looking better! Drained all of the fuel, changed filter that was clogged and full of grunge. Plan is to fill up and add marvel or seafoam and change fuel filter each of the next 5-6 fill ups. Hopefully tank will get clean!
Jesse
2001 330i DD
